Old 02-27-2006, 09:22 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Running 5 Cylinders
WTF, my car is running 5 cylinders again... awhile back (after getting hit)... my car blew out a spark plug (#2 cylinder)... I replaced it, no problem... last Friday on the way back home... it blew out again... I looked, and the plug was hanging... it was covered in crud (burned, old looking oil, new spark plug, only a month old)... The whole side of the plug was gone, the electrode completely gone... the car's still running... so I took the wire off and am running 5 cylinders, I don't give the car another week or two... it's losing major oil outta the empty port, but I'm checking and throwing in the cheap stuff daily... any ideas why this one keeps going out?
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 02-27-2006, 09:33 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Running 5 Cylinders
Sounds like oil is getting past your rings, or your valve stem seals pretty badly.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-27-2006, 10:03 AM
Mikelb's Avatar
so, nothing I can fix cheap and easy right?... b/c I'm not throwing much more into it... it's totalled and insurance isn't helping... so, I'll have to sue the guy
Old 02-27-2006, 10:30 AM
AutostradaVR4 AutostradaVR4 is offline
contact your insurance rep and ask wtf is going on...did he not have insurance or something? Ask them why you havnt gotten a check yet.
about the car...sounds like a pretty major problem. Id say talskinyguy hit the nail on the head. was the plug firing before it blew out? if not, maybe you need wires or a coil or something like that.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-27-2006, 10:37 AM
Mikelb's Avatar
well, I tuned it up only a few months before... and it was running fine... though after he hit me, the exhaust sounded different... and I noticed the left pipe is bent a little, and a gasket blew out on the exhaust, so I'm guessing the cat got clogged up or too much pressure from the pipe being bent...
Here's what the ins agent said:
At this time, there is nothing I know of that can be done in order to
assist you in this unfortunate incident. If there are anymore questions or
concerns please feel free to contact me on my cell phone ***-***-****.
Unfortunately, I work both inside and outside the office and need to
respond to messages as received, I am sorry I missed you on my last call.
Regards,
Joe
I've left out his personal info for protection... but that's apparently what he can do... b/c I was given a ticket for being over the center, which was bogus and I have proved that with pictures, but dealing with a crooked cop makes things even harder... so I have to wait for that to go to court... and then I can sue Tant and his insurance company...
Old 02-27-2006, 05:12 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If oil is getting past the cylinder that badly you most likely have a cracked piston. My engine is in sorry shape and my plugs are never covered in oil.
Old 02-28-2006, 07:09 AM
Mikelb's Avatar
Well, I can't say for sure that it had spark... but I assume it did... as it ran much better with the new plug... is there a possibility that the piston could have hit the plug??? (SOHC, non-interferance)...
I used to have a 3.8l Taurus, and one of the spark plugs flew out of the port after being hit with the piston... and I'm certain that's what happened, because inspection of the plug showed a massive impact to the bottom of the plug, while it was still in the port (the threads on the plug were stripped)
Also, could I rethread the holes, and put a spark plug non-fouler in the port?
Old 02-28-2006, 05:35 PM
Stealthee's Avatar
The piston will not hit the plug unless a rod breaks. And non interference has to do with piston to valve clearance.
Old 03-01-2006, 07:07 AM
Mikelb's Avatar
I didn't really think it was an issue... but what if the car was to jump timing, there'd still be no possibility?... I'm pretty sure the rod isn't broken, as the car is still running... I know the valves are opening and closing... you can hear that...
Old 03-01-2006, 07:24 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
I had a problem, kinda similar to this. Except, I was running on 4 Cylinders for the longest time. Wow, a 4 Cylinder stealth really isn't a car to be driving, I can tell you that. Two of my Spark Plug cables were really bad. I mean, old, broken, rips in the cables and everything. So, I figured that's why I was only running on 4 Cylinders. Well, I bought 8.5 MM Spark Plug Wires for her, and now she is running better then ever, and also threw on a Air Filter, she seems so much better runnning.
1991 Dodge Stealth R/t
Old 03-01-2006, 07:27 AM
Mikelb's Avatar
I'll check the wires, but I had replaced them a/b 6 months before... just the Bosch replacement... I heard those 8.5mm are even worse than stock... I don't really wanna throw out money into this car for it to die... b/c it's already totalled... I just don't see the finances right now...
Old 03-01-2006, 04:43 PM
Stealthee's Avatar
Absolutely no possibility of the piston hitting the head period.
