Motor mount and oil pan replacement
Ok well a few more questions for ya'll. I replaced my axles and discovered the reason for the pass side failure. The psteering leaked the previous owner had must have been a leak for a very long time. The fluid ate through the rubber of the front engine mount. The front of the engine dropped down some and the axle rubbed a spot into the frame. I am planning on replacing the mount tonight and I was wondering if anyone knew a secret to removing the bracket and mount assembly. I know the book way but was hoping for a simpler way.
Also he had hit something with the oil pan, will the new style cast alum. oil pan fit my 97 gtp? We have a 3800 series two core sitting at the shop, since I need to raise the engine to do the mount I figured I would replace the pan now. Thanks John |
Re: Motor mount and oil pan replacement
The GM computer shows all 97-03 Vin-K (normally aspirated) and Vin-1(supercharged) 3800's using the same oil pan.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Ok this one must be an 04 or 05 then, it is definately a different oil pan. I'll just have to go back and change it later, thanx
The GM computer shows the 04-05 using the same gasket, pick-up screen and oil level sensor as the 97-03, so unless it would interfere with the sub-frame, they should be intechangeable.
cool I am pulling the mount now so I will do some measuring and see. I will post the findings here, in case someone needs to do the same thing.
