Old 02-27-2006, 08:57 AM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
'98 2.2 idling problem plz help
Hello. I have a 98 2.2l cavalier coupe 5 spd. As of about three days ago, whenever my car is running and idling the rpms are normal then out of where they drop almost to stalling point. Also when i accelerate sometimes the car seems to misfire and the car jerks. The car has not stalled yet though. I do not have a tach so i can't give you exact numbers. My "check engine" light is not on. I do not know what the problem is. I talked to a guy at Auto Zone and he said to wait untill the light comes on then bring it to them to see. He said it might be the o2 sensor or a temp sensor. Thanks for the help.
Old 02-27-2006, 11:30 AM
Jenn641 Jenn641 is offline
Re: '98 2.2 idling problem plz help
I'm no mechanic, but, I had something similar to this situation happen to me with a Mazda I had. It turned out that my air intake tube was cracked, and letting air in. You might want to see if it could be that. It ran me about $100 to fix, but definitely solved the problem!
Old 02-27-2006, 11:07 PM
thanks. ill check it out and ill let you know if that is what the problems is.
Old 02-28-2006, 07:41 PM
i replaced the spark plugs and it fixed the problem. now when it idles it rumbles like i have 4 more cylinders, then i actually have. not sure if its normal. ill wait and see for tomorrow
