Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-27-2006, 02:35 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Motor Mounts
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
I've got this really annoying nock when i shift gears, and when i floor it. And i know it my motor bounceing so i decided to order them. But on some pictures i have saw there is 4 mounts i only know of 3. One on the motor, one on the tranny, and one that mounts to the thing that runs under the car and bolts to the frame. Where might the other one be?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-27-2006, 04:00 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Motor Mounts
The other one is in back of the motor it's actually bolted to the trans (i just took this one off) is that kit for all four mounts? It's not very specific, and is it turbo or n/a cause i know the mounts are different.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-27-2006, 04:27 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Motor Mounts
The motor mounts might be different but the inserts are the same. Good luck putting them in.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-27-2006, 04:32 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Motor Mounts
Thats pretty cheap isnt it? I might have to order some to
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-27-2006, 05:02 PM
ez1286's Avatar
Re: Motor Mounts
The turbo and n/a motor mounts are the same? I didn't think so considering the engines are backwards and nothing else is the same...
Old 02-27-2006, 05:03 PM
blk_srt's Avatar
Re: Motor Mounts
the mounts are different but the inserts could be the same
Mods:
Old 02-27-2006, 07:11 PM
xavier3jr's Avatar
Re: Motor Mounts
the mounts are diffrent but im pritty sure the inserts are the same. anyone never put them in? how hard are they lol. might wana get some anal lub for this job
Old 02-27-2006, 07:13 PM
blk_srt's Avatar
Re: Motor Mounts
umm...I think some grease might work better than "anal lube" but you probably have more of that lying around
Mods:
Old 02-27-2006, 07:22 PM
xavier3jr's Avatar
Re: Motor Mounts
hardy har har
Old 02-27-2006, 08:17 PM
george536's Avatar
george536 george536 is offline
Re: Motor Mounts
mine were pretty easy, to do, but you will need to lube the insert pretty good for the big mounts.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 02-27-2006, 11:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Motor Mounts
At 37 bucks I have to assume that is the partial kit with just the front and rear, which simply slide into the stock rubber mounts to fill the gaps. If it's the full kit somehow, the two side mounts are a bit more work. Some poeple get fancy with the torch and hacksaw tag team, but I prefer to pay my machinist 10 bucks to press the old metal sleeved rubber inserts out. The new ones go in easily with a vice, just don't bother tryign to put the metal spacer/sleeve in until both halves of the uerethane are in.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-28-2006, 07:18 PM
xavier3jr's Avatar
Re: Motor Mounts
I'm pretty sure its the full kit energy suspension has some very good deals. i got my shifter bushings for only 12 bucks. but we'll see when it gets here.
