Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-27-2006, 12:33 AM
bigjrus bigjrus is offline
Question need some help with fitting 89 vic
Hows it goin out there peoples,
Just bought a 1989 Crown Victoria last night for 325$ at an auction in mint cond and looking around to see if anyone may know a good site to help find a set of nice rims to fit it. Nothing to fancy just give it a new look, but it seems like there isnt alotta rims that fit for it. Ive owned an 88 Linc TC since I got my licence and was wondering if they would be the same lug pattern since linc is a luxury ford ( i think). If i would get any help at all it would be wonderful of u guys and gals.
Thanks again,
Rusty
Old 02-27-2006, 08:59 PM
amo4387622 amo4387622 is offline
Re: need some help with fitting 89 vic
well if you are going to stick with the stock size it is 15x6.5 but 15x7 will work also. And the bolt pattern is 5x114.3mm. and the off set is +20mm. If you want to go with a bigger size let me know? as for sites I like to use www.tire.com but when you look up by car you have to use a grand marquis instead of the crown vic or you will not get anything, Also http://superbuytires.com/ has some good rims too for cheap prices.
Old 02-28-2006, 12:33 PM
thanks for the help, i was thinking of taking it to a 16 or 17, i really wanna find some wicked wires but i havent seen a set since probably '95. thanks again for the help
rusty
Old 02-28-2006, 01:55 PM
Ok well you will need a 16x7 or 16x7.5 with +20mm offset and the recommanded tire size for those rims would be a 225/60 R16. For the 17 you need a 17x7.5 or 17x8 with +20 offset and the recommanded tire size is 245/45 R17. Now on the tire sizes you can go bigger but those are what I would choose for those size rims. and as for the wire wheels the second site I gave you has them for around $99 each for the 15x7 rims.
Old 02-28-2006, 02:49 PM
thank you so much for your help, like i said i wanted to keep it elegant and classy but not low down, just kinda givin it a look that no one has around here, thanks again
rusty
