Old 02-27-2006, 12:21 AM
josh95mx josh95mx is offline
D15B2 to D16Z6 swap need some help!
well iv been reading for days, and still dont have all my questions awnsered. and No help form anyone on Honda tech.
i have an 88' civic with the DPFI, so i bought a Z6 to swap in. i bought the SI harness, a PR3 ECU, and the fuel resistor box is in the mail. now i know im going to have to run some wires from the ECU to the Vtec solonoid. now do i need to run any extra wires for the injectors even though i have the si harness?
and is their an OBD 0 distributor i can run on the Z6 head that will bolt up to the Z6. i figured i could probably make some brackets to make it bolt up, but i also read that i needed a distributor off of a Vtec (is this true). i also read that the TPS might not work, it might be backwards? is this a problem even though im using the SI harness? is their anything else i need to be aware of, as i need to get this thing running.
any help is greatly appreciated.
Thanks
88' civic
D16Z6 swap in progress
95' Mazda MX3
AWD conversion, turbocharged
https://home.comcast.net/~josh95mx/
Old 02-27-2006, 06:14 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: D15B2 to D16Z6 swap need some help!
Do a search on a Z6 swap on google or something, there are a bunch of how-tos explaining what all you need to do, they answer all of those questions, minus the fuel injectors, which if you use the Si harness i don't see you having to run extra, but from what i have heard its easier to just use the stock DX harness over the Si.
if i wasn't on dail up and lazy i would get you the links. I know www.4thgenerationcivic.com used to have a few links on it, but last i heard the site was down, could still check though.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-03-2008, 01:02 PM
BIGTEX84's Avatar
BIGTEX84 BIGTEX84 is offline
sorry to bring up old threads, but i am not having much luck finding anything on this subject either. i am running an 89 std civic hatch with the stock d15b2 dpfi. does anyone know of a write up that has been done and where i can find it
Hey, if you are looking for a good deal on a motor swap, with fast shipping and great customer service, Ive got just the place for you. . . . . . . . TO STAY AWAY FROM!!!!! WWW.OSAKAJDMMOTORS.COM=BULL$H!T!!!!
Old 11-03-2008, 02:22 PM
Tony's Avatar
TLD Member #1
FAQ is a great place to start. Or any of the recent threads that have been started, a lot have to do with doing a d16z6 swap or something similar.
Tony
Old 11-03-2008, 04:53 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Try searching MPFI swap... then searching Mini-me. You'll need both, since that's essentially what you're doing... if you're not actually using the mini-me setup, and you're just swapping in the Z6, ignore the engine building part.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
