Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-26-2006, 10:36 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
AWD drivetrain compatibility
I may be acquiring a 92 TSI AWD shell soon. I am going to need the whole engine/drivetrain except the 4 bolt rear. It will be getting a 6 bolt engine. I am wondering about the tranny, t case, axle, and driveshaft compatibility. Will any 1g AWD tranny, t case, axle, and driveshaft work, or will only certain years work? Thanks guys.
EDIT: Sorry for not searching thoroughly, my head is pounding so hard I can barely concentrate on the screen.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-27-2006, 01:13 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: AWD drivetrain compatibility
I believe all 1g axles and driveshafts are the same. The tranny and tcase changed over the years. 90 tcases have a different spline count, and the tranny output shaft does as well naturally. You can mix and match by swapping output shafts (need to remove the endcase and pull the VC to do it), or just make sure the tranny and tcase you get have the same spline count.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-27-2006, 03:03 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I think one has 22 splines and the other has 23, not sure which is which, I have an awd trans and tcase (matching spines) off a 90 gsx (manual trans), let me know if you're interested.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-27-2006, 04:02 PM
Thor06's Avatar
Jizzed In My Pants
DAMN GUYS! I just found a 90 TSI AWD with a blown head gasket for cheap (not telling because I dont want any of you to get it before me )! I realized that building a shell would cost lots more and be much more difficult, so I doubt that I will be getting that one guys shell... to build. It does have a EPROM and a 4 bolt, I may buy it just for those. Is the 4 bolt a direct replacement for the 3 bolt?
Old 02-27-2006, 10:02 PM
AF - Advisor
I've never done the 4 bolt swap, but I've seen someone do it in less than an hour, so it shouldn't be too bad. Maybe half a day for a first timer?
Kevin Jewer
Old 02-27-2006, 10:31 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Its about time you get yourself a dsm
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 02-28-2006, 10:18 AM
Thor06's Avatar
Jizzed In My Pants
FUCK YEAH!!! They buyer (admin of dsmstyle.com) backed out, leaving me next in line! Appearantly, the admin went to check it out yesterday (monday) and said he'd get back to the seller this morning. Well, he doesnt want it and when I talked to the guy yesterday he said that if the admin didnt want it, it was mine. There will be a thread on this soon, as soon as I get it which will be either this weekend or spring break which starts next thursday. FUCKING YES GUYS, THOR IS FINALLY GETTING THE CAR OF HIS DREAMS!!!!
Hey pr_ricer, want to help me change a head gasket? I will drive it back the way it is, but if I can change it down there, I will. Where are you at again?
EDIT: Shit, I didnt realize you were so far away, Austin is on the border with Iowa right? Oh well, i'll just have to buy lots of coolant!
Old 02-28-2006, 03:26 PM
blk_srt's Avatar
Yeah austin is like ~20 miles from the border, otherwise I would be more than happy to help you out. If you get all the parts before hand it will go really fast. If you need any help just let me know and I can try and walk you through it since I just did it on my car
Mods:
