Old 02-26-2006, 09:11 PM
81montedriver 81montedriver is offline
shocks and springs
2 questions:
I have a 95 blazer and...
1. I plan on buying new shocks, but I cranked the torsion bar in the front to lift it about 2 inches. Should I buy a 2in. longer shock or stay w/ the stock size?
2. I have seen add-a-leaf kits for 95 and up Blazers, but it does not make sense to me how adding a spring will lift the rear since the axle is above the spring and below. It seems to me that adding a spring will have the reverse affect. Am I just imagining things?
Thanks for any help.
Old 02-27-2006, 12:24 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: shocks and springs
Stock shocks will be fine.
As for the rear springs, any reason why you want to add a leaf?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-27-2006, 07:51 AM
billibong's Avatar
billibong billibong is offline
Add a leafs are usually used if you plan on towing and you need to increase the support in the rear.
If you are trying to lift the truck either get a body lift kit or a suspension lift kit to lift it to the point you want.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 02-27-2006, 02:07 PM
yes that is one of the reasons. I will be doing some towing soon so I wanted to add some support to the rear. I was also looking to level the rear since it now sits lower than the front since I did the torsion bars. Besides, if I did go the route of a suspension lift, all it will do is put the springs over the axle rather than under how it is now. And a body lift will give me more clearance for tires but will not level the vehicle like I am looking to do.
