Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-26-2006, 08:55 PM
bearinns08's Avatar
bearinns08 bearinns08 is offline
Send a message via AIM to bearinns08
ABS light
i had a problem w/ my batter about a week ago, after jumping it once, it has run fine. But my ABS light is still on, can anyone give info on this??
Old 02-27-2006, 06:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: ABS light
Is your Trac off light on too? If so, you may have a bad wheel speed sensor, which is contained in the hub bearing. I would have the car scanned with an abs capable scanner to see which what is causing your ABS light. I believe the two (the battery problem and the ABS slight) are unrelated.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-03-2006, 05:17 PM
wethepplebmxer wethepplebmxer is offline
Re: ABS light
I just had the same thing happen to my gtp. It ended up being the hub so get it checked out... it's gonna be a couple hundred to replace the hub but it's prolly a good idea.
The GTP's Kill list:
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- 90ish Prelude (modded)
- Eclipse GTS
- 03 or so Civic Si
- 96 Eclipse GS-T (some mods)
- 04 WRX (manuel)
- 94 Prelude V-tec (head, cat, more...)
- 06 WRX
- 96 T/A
- 05 300C
Mods: Thrasher CAI, 3.4 pulley, straight pipe (res and u-bend delete), ZZP PCM, Colder plugs, new wires, 180 t-stat.
Old 03-04-2006, 12:51 PM
Madmunky Madmunky is offline
Send a message via MSN to Madmunky
Re: ABS light
That happened to me too, the ABS light was constantly on, so in late november I took the car back to the place I bought it in Sept of last year and had them check into it. They told me that they found 6 "old codes" stored and they thought that could be the problem, couldn't find anything mechanical so they cleared the code, a week later it was back. Then just a few weeks ago I found I needed new pads, while replacing them I found that my one caliper had seized. I went to a new shop, got it fixed (also needed a rotor because it had been like that for so long, if the first shop had of found that it would of saved me a lot of money) and the light hasn't come on since. Needless to say I'm not going back to the place I bought it again.
Jamie
1995 Pontiac Grand Prix GTP
3.4L DOHC
only mods are aesthetic, for now
My Cardomain Page
Old 03-06-2006, 02:05 PM
bearinns08's Avatar
Re: ABS light
I know I need to replace my brake pads, that is a spring break project. Maybe that will take care of it?? or is it definately a deeper problem such as: a caliper, rotor, or sensor??
Old 03-06-2006, 05:59 PM
richtazz's Avatar
Re: ABS light
Unless your brakes are pulsating really bad, worn out pads wont cause an ABS light.
Old 03-06-2006, 06:21 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: ABS light
I agree with Rich. I've seen really bad rotor and caliper problems but none ever triggered the ABS light.
Timeslip 08/12/06
AF Community Guidelines
Old 12-20-2006, 12:43 PM
Binkladen Binkladen is offline
Re: ABS light
Hello all, I'm new to AF so bear with me. I was wondering if disconnecting the battery might reset or clear any of these ABS codes or what have you? My ABS light and Traction Off light came on just from one bout of heavy braking.
Old 12-20-2006, 04:17 PM
maxwedge maxwedge is offline
A990 racer
Re: ABS light
Welcome to AF, this thread is way too old, start a new one for more responses.
Old 12-20-2006, 06:59 PM
RT87 RT87 is offline
Re: ABS light
A majority of ABS problems are in the wiring from the wheel sensor into the main harness. You need to get the code read (Usually at a dealer) and if it comes up with a particular wheel, I would go to the junkyard and get another harness for that corner.
Old 12-20-2006, 11:53 PM
BNaylor's Avatar
Re: ABS light
Sorry but if an AF Moderator suggests the thread is too old then please do not post in it. If you have an issue or question start a new thread. Threads over 3 months should not be resurrected. Thread closed.
Timeslip 08/12/06
Closed Thread
