Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-26-2006, 09:36 PM
JASDYER561 JASDYER561 is offline
Keyless Entry
Help !!!! I Just Bought A Program Off Line To Reprogram My Keyless Entry And It Came With Very Easy Steps To Follow But Here Is The Problem Step 2 Is To Access Program Connector Taped To The Wiring Harness Located In The Trunk. I Cannot Find This.does Anyone Know What This Looks Like?
I HAVE A 1996 FORD THUNDERBIRD 4.6
Old 02-27-2006, 04:43 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Keyless Entry
J561- Thanks for cleaning up the Tech Help thread. Open your trunk and remove the panel that covers the drivers side rear wheel well. You will notice a box with a red button which is the Inertia Fuel Shutoff switch. Just in front of the IFS is a larger box which is the Anti-theft Controller Module. The box in front of the ACM is the Remote/Keyless Entry Module. Below the ACM and R/KEM is the connector you are looking for. I hope this helps you.
The Original 97Bird
Old 02-27-2006, 08:30 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless Entry
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 02-28-2006, 06:48 PM
Re: Keyless Entry
OK IM OFF TOMORROW AND I WILL TRY THIS. I THOUGHT I LOOKED AND DIDNT SEE A BOX BUT I WILL LOOK AGAIN. IS THIS SOMETHING THAT IS FROM THE FACTORY 1996 FORD THUNDERBIRD. ( I WOULD THINK)
WELL I'LL LET YOU GUYS KNOW HOW IT TURNS OUT
Old 03-01-2006, 05:19 PM
97Bird's Avatar
Re: Keyless Entry
You will be looking for a connector BELOW the box!!!
The Original 97Bird
