Old 02-26-2006, 07:45 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Bad Draw
I have a pretty bad parasitic draw. I really dont know where its comming from. I think its from my system. If I leave my truck without starting it for a day its dead. How can I check my system to see if it is the cause.
EDIT: I know this isnt the silvy forum but I figured someone on here might be able to help.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 02-26-2006, 08:12 PM
badasschevy123 badasschevy123 is offline
Exclamation Re: Bad Draw
First Check Battery Charge, And Any Other Shorts Sry Im Not Much More Help, Ooo And Go To A Firestone Or Somethin To Have A Dynostics Run On Ur Car
NEVER DRIVE FASTER THAN UR GADIAN ANGEL CAN FLY
Old 02-26-2006, 08:16 PM
korndogg's Avatar
Re: Bad Draw
I work in a shop and we checked my batter, starter, and alt and they are all fine. I think what Im going to do is put a test light on the negative terminal and cable and then disconnect the cable and start pulling fuses...if i pull a fuse and the light goes out then I know that is my problem.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 02-26-2006, 08:18 PM
Re: Bad Draw
Sound Like U Know Wat Ur Tlkin About I Hope U Fix It
Old 02-27-2006, 11:22 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Re: Bad Draw
I have the same draw on my car, i think its because the person who owned the car before me put in a new electric fan and moved all the power wires probably touching them to grounds or cracking them.
It would be better to put the test light on your POSITIVE terminal and touch it to your POSITIVE cable (closed circuit) THEN pull fuses, the fuse boxes run more through red then black so you might have a better chance finding it this way. Hope you find it.
Old 02-27-2006, 02:10 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Bad Draw
They sell draw tester's. Turn off all accessorys and then use each while someone pays attention to the tester. You should be able to figure it out pretty quickly but I would bet alot of money on the system. I know my amp killed my voltage at idle and I had a 140 amp alternator.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-27-2006, 09:51 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: Bad Draw
By 'system', did you mean alarm system?
Ive heard that in most cases, the cause of draws like this are caused by: an issue with power door lock systems(usually a relay), aftermarket alarms, under-hood or glove box light staying on, or an aftermarket stereo systems.
The most common two are the door lock systems and the aftermarket alarms...
Again, this is just what I have heard, I dont claim to be an expert(Im far from it..lol) but if you have to dook for the source of a drain...Ive heard you should start there...
Old 02-27-2006, 09:57 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Bad Draw
System is slang for Audio system.
