Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-26-2006, 07:01 PM
KEWINA KEWINA is offline
325is window problem
My window does not go up all of the way when I shut the door unless I slam it REALLY hard. I was told that there is an adjustment thing somewhere around the door. Also, what kind of glue works best in cars? Like, glueing plastic to plastic/metal.
Thanks,
Kevin
Old 03-17-2006, 10:54 PM
goodwrnc3 goodwrnc3 is offline
Re: 325is window problem
There is a micro switch in the door latch that controls the window to go up when you close the door, The micro switch might be loose, Or you need a new door latch, I had to change the door latch on my 325IS, I do not remember seeing any type of adjustment
Old 04-10-2006, 01:29 AM
sfjamal sfjamal is offline
i think it has to do with ur door panel, if its not glued properly to door, it is affecting the window sliding mechnism.
