Old 02-26-2006, 06:32 PM
Gillett Gillett is offline
96 Lumina APV Tailgate lock
Looking for a bright idea...
The tailgate of my 96 Lumina APV is locked closed. When I unlock with the remote, I hear a quiet 'tick' of the unlock (expecting it to be a bit louder), but it won't open. The key won't go in the lock. I trird removing the plastic over the lock mechanism from the inside, but it looks like you have to have the tailgate open to get at the two screws that are in the end of the plastic. Any bright ideas for what I should try next?
Thanks!
Old 02-26-2006, 08:31 PM
stgninja stgninja is offline
Re: 96 Lumina APV Tailgate lock
I had the same issue on my 95, APV. Removed all the screws I could get to from the inside. I have long arms and was able to flex the inner panel enough to work the mechanism. I did run the risk of cracking an already cracked panel.
Old 02-27-2006, 01:57 PM
jebjr jebjr is offline
If you take a long screw driver, you can open the latch from inside the van. (either push down on the left side of the latch mechanism or pry upward on the right side). you'll have to play with it a little bit but its not hard to do.
Old 03-08-2006, 04:49 PM
Thank you both!
Before I tried either, I wanted to make sure it was warmed up - it's been cold and the garage isn't heated. Hopefully this weekend I'll get at it and *carefully* put an electric heater in the back to warm it up first.
Old 03-08-2006, 04:59 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Originally Posted by Gillett
Thank you both!
If all else fails, I've got a .45 you can borrow. Opens anything...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
