Originally Posted by 98gpking
I have a 93 Ford Probe GT with 129,000 miles. Recently I noticed a loss in coolant and heat. I filled the coolant resevoir and the radiator. The heat came back and the overheating stopped. I looked under my car, and on the left side I noticed a constant flow of coolant. My only guess is that the water pump is bad. The problem is I do not know how to replace the water pump. If anyone has an links or instructions on this process please respond.
Thank you
just did that on my probe. can tell u this. it involves, valve cover removal,
timing chain cover removal, belt, crank pully removal, engine raised or lowered to get in there. my advice. take it to a shop. lot less headache than what i had. good luck.
