Old 02-26-2006, 03:31 PM
dampontiac dampontiac is offline
97 lumina help
hey all,
recently put in a motor in a 97 lumina, everything went in well and when i started the engine there was coolant coming out near the back of the motor.
i guess this is a common thing but i dont remember what it is that i have to replace or fix. If any one knows could you help a fella out???
thank you all in advance for any help that you would be able to give me
Old 02-26-2006, 04:29 PM
maxwedge maxwedge is offline
A990 racer
Red face Re: 97 lumina help
Short on more definitve info, where, intake, freeze plug, coolant hose, you are the one on site looking at it.
Old 02-26-2006, 10:10 PM
Re: 97 lumina help
sorry its the 3.1liter and i am not sure where it is really leaking from just the rear of the engineon the pass. side thats about all the info i can give for now
Old 02-27-2006, 01:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 lumina help
the only thing in that area where coolant would come from is the heater core drain tube, all other hoses and pipes run across the front or drivers side.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-27-2006, 02:01 PM
jebjr jebjr is offline
Re: 97 lumina help
rear is most likely a heater hose. I would also check the thermostat and water pump to make sure the coolant is simply traveling down the exterior of the engine.
