Old 02-26-2006, 03:09 PM
mygfsgtp mygfsgtp is offline
need help : 96 headlight replacement
im trying to replace the sealed beams on my gfs 96 gtp, im not too familiar with teh procedure on how to do it , could someone help me out on this one. thanks guys
Old 02-27-2006, 08:37 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: need help : 96 headlight replacement
If you have the mini-quad system with the 4 sealed beams, there is a trim ring with 4 screws that holds the bulb in the mounting bracket. The screws get rusty and can be a PITA to get out. I've found spraying them with a penetrant like PB blaster or Break Away usually gets them loose. THE lamp comes out from the front, then just unplug it and installation is reverse of removal. If you have the type that uses the halogen capsules, they just twist out of the lens assembly from behind. If you have the capsules, don't touch the glass part with your bare hands, as oil from your skin will cause them to overheat and fail prematurely.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
