Old 02-26-2006, 03:08 PM
Anthony B Anthony B is offline
2005 Caravan airbag light reset
Have 2005 Caravan repairable. Main computer, airbags, and airbag control module are from parts van. New pre-tensioners installed. Cannot get airbag light to go out. Any ideas?
Old 02-27-2006, 11:49 AM
93 Freshcort 93 Freshcort is offline
Re: 2005 Caravan airbag light reset
Brake sensors could be dirty, or a bad ground. My guess is because of the year of your vehicle it's the sensors need cleaning.
93 Escort 1.9L LX Hatchback - 285k miles
04 Explorer Sport Trac - 45K Miles
Funny & Offensive TShirts
WWW.AMERICASFUNNIESTTSHIRTS.COM
Free Resource's & Advertising @
WWW.LASTCORP.COM
Old 03-01-2006, 07:38 PM
1thunder 1thunder is offline
replace front impact sensors then must clear codes with scan tool or lamp will stay on
Old 03-02-2006, 03:22 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
On some Toyotas there is a procedure that lets you reset the light by grounding wires at a test plug under the hood by touching ground three times in 3 seconds. Does anybody know if Chrysler was gracious enough to bestow that ability to their minivan DIYers? Knowing how easy Chrysler has made it to repair any malfunction on their wonderous machines, I would be shocked if they didn't. Ya...uh hu.
Old 03-02-2006, 03:32 PM
Thanks, I will give it a try and report back.
Old 03-02-2006, 03:34 PM
Thanks, The sensors are relatively cheap so I will give it a try. Do you know if Chrysler needs to clear the codes or is there an aftermarket scan that works for Chrysler airbags?
Old 03-03-2006, 07:05 AM
slantsixness's Avatar
slantsixness slantsixness is offline
There's an aftermarket scan tool, but it's not the typical "Actron" code reader we all (should) have, and it costs too much, like everything else we have to have! I don't beleive the code readers will even work on a 2005 anyway!
Once you have it fixed, and the airbag modules are new, take it to somebody who spent the bucks on the tool, and pay them to clear the Air bag light....gotta be cheaper than buying the tool!
Whatever you do, don't think for a minute that grounding pins on the service connector is going to work. Unless of couse you want to buy a new BCM or ECM!
Tom
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 03-03-2006, 09:52 AM
Tom
Thanks Tom, I will try to find someone with the reader. And thanks for the warning about grounding pins.
