Old 02-26-2006, 02:22 PM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
Fluid Change Intervals???
I need to find out the milage intervals to perform all the basic fluid changes...
-Tranny flush and new filter
-Front & rear diff fluid
-Transfer case
-Fuel filter
I'm sittin at 29,000mi right now and I can't for the life of me remember when I'm supposed to take care of all this stuff.
Thanks a lot!
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 02-26-2006, 03:19 PM
B18B_EG6 B18B_EG6 is offline
Re: Fluid Change Intervals???
Transmission Flush & Filter - 50,000
Fuel Filter - 30,000
Front Differential - 30,000
Transfer Case - 50,000
Rear Differential - 30,000 Non Synthetic or 50,000 Synthetic (Has A Tag)
Power Steering - 30,000
Coolant - 150,000 or 60 Months
Old 02-26-2006, 06:18 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
If all else fails read the owners manual and use the recommended fluids.
Also on the coolant manf says 150k or 5-7 years
I would not go over 3 years or 50K.
Also on the K&N filter keep it cleaned and go very easy on the oil in it and get a can of MAF sensor cleaner.
And use it often. Also for warranty work put your oem filter back in before you go in.
That K&N oil just loves to migrate into the MAF and air tempt sensors.
MT
MT
Old 02-26-2006, 07:36 PM
FiTxAg04's Avatar
Good stuff guys. Y'all helped out a ton. Thanks a lot!
2004 Chevy z71
Old 02-26-2006, 07:40 PM
FiTxAg04's Avatar
So, do the diffs from the factory have synthetic or conventional fluid in them? Or does it vary from truck to truck? Can I put synthetic in no matter what? I'm tryin to switch as much to synthetic as I can.
2004 Chevy z71
Old 02-26-2006, 08:39 PM
yakk's Avatar
yakk yakk is offline
Here's a bit more besides just fluids:
Clutch Fluid Replacement
Vehicles with 6-speed manual transmission only: Change clutch fluid.
Interval: Every 25000 miles.
Engine Air Cleaner Filter Replacement
Vehicles without a filter restriction indicator only: Replace the engine air cleaner filter.
Exhaust System Inspection
Inspect exhaust system for loose or damaged components.
Fuel System Inspection
Inspect fuel system for damage or leaks.
Automatic Transmission Fluid and Filter Replacement (Allison Transmission Only)
Vehicle with Allison Transmission only: Change automatic transmission fluid and filter.
Interval: Every 50000 miles unless the vehicle is mainly driven under one or more of these conditions: 1) In heavy city traffic where the outside temperature regularly reaches 90 F (32 C) or higher 2) In hilly or mountainous terrain 3) When doing frequent trailer
Interval: Every 50000 miles.
Evaporative Control System Inspection
Inspect evaporative control system.
Transfer Case Fluid Replacement
Four-wheel drive with automatic transfer case only: Change transfer case fluid.
Cooling System Service
Drain flush and refill cooling system. Inspect hoses. Clean radiator condenser pressure cap and filler neck. Pressure test the cooling system and pressure cap.
Interval: Every 150000 miles or every 60 months whichever occurs first.
Automatic Transmission Fluid and Filter Replacement (Vehicles without Allison Transmission Only)
Vehicle without Allison Transmission only: Change automatic transmission fluid and filter.
Interval: Every 100000 miles unless the vehicle is mainly driven under one or more of these conditions: 1) In heavy city traffic where the outside temperature regularly reaches 90 F (32 C) or higher 2) In hilly or mountainous terrain 3) When doing frequent trailer
Spark Plug Replacement and Spark Plug Wire Inspection
Replace spark plugs and inspect spark plug wires.
Interval: Every 100000 miles.
Engine Accessory Drive Belt Inspection
Inspect engine accessory drive belt.
Interval: Every 150000 miles.
Manual Transmission Fluid Replacement
5-speed manual transmission only: Change manual transmission fluid.
You can also register with Chevy here and they'll email you reminders.
Old 02-26-2006, 10:02 PM
Alright, all front differentials had conventional in them from the factory, some rear differentials had synthetic and others had conventional. If it had synthetic as a factory fluid it will have a blue plastic tag right above the fill plug. You can use synthetic in everything if you would like. Its just if it is tagged synthetic, thats what came factory and is recommended by GM.
As for the transfer case, Im not to sure if the newer models now all have the synthetic Auto Trac 2 fluid or not. Some from around 1999-2001 used ATF in the transfer case and the interval for those was 30,000. It all depends on what transfer case you have in there. There is a tag on that as well that will say what transfer case you have and then you can go from there. Another way is to just look at the fluid in there right now. If it is pink or red then its ATF. If its blue or green then its Auto Trac 2.
Hope this helps.
