Old 02-26-2006, 01:23 PM
intel_guy intel_guy is offline
Magnaflow Universal Cats
Anybody ever use the Magnaflow universal 2.5" cat on their truck? I'm wondering because they're $60 compared to OE $400+
Old 02-26-2006, 02:53 PM
HD2500 HD2500 is offline
Re: Magnaflow Universal Cats
I just bought a universal Magnaflow muffler for my truck. $125 shipped as oposed to $500 for the cat back sustem. I was trying to find out if the muffler I bought was the same as the one that comes with the cat back system but, really didn't get any answers either way. I read that this muffler was still going to sound off more and give me more power than my stock muffler. I'll let you know next week after it's installed, if your still looking that is.
Old 02-26-2006, 06:41 PM
Thanks. I will be looking for that at sometime, but right now I am asking about the Universal Magnaflow Catalytic Converters...I keep throwing code P0430 and dont/wont spend $450 just for a new OE catalytic converter. I would spend $60 for the magnaflow if it works. According to the sale page it is up to the ODBII spec.
Old 02-26-2006, 07:12 PM
Oh yeah, didn't see the "cat". You can probably get that O2 shut off, but that takes money too. You post over @ GM-Trucks.com? If not someones got the same issue as you over there. Good Luck
Old 02-26-2006, 07:14 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What year engine and mileage.
Code 430 can be caused by a lot of other things besides cat.
Have you had the cat tested?
And even if the cat is bad you need to find out why it went bad.
Tune up engine running problems. Any other codes?
MT
MT
Old 02-27-2006, 07:06 PM
99 Silverado LS 1500 Ext Cab 4x4, 134000 miles. The motor sounds and feels tight. It doesn't burn any oil, so I guess you're right about step 1...find out of the cat is bad. I'm thinking since it's 130k miles and I suspect no maintenance has been done on the truck except for oil/filter changes, it is safe to assume bad cat. If testing is cheap its definitely worth a shot. Thanks a lot.
Old 02-27-2006, 08:12 PM
MT-2500's Avatar
AF - Advisor
Cats are hard to kill. But good mantiance helps keep them going.
Here is a link on code 420/430 codes.
http://www.troublecodes.net/articles/catfailure/
MT
MT
Old 02-27-2006, 09:19 PM
Would exhaust smell indicate anything? I notice it has a rich smell, stronger than I am used to. It doesn't have any rotten egg smell which I've been told is a sure sign of a bad cat, but hey it may have worn off over time. I just got the truck 7000 miles ago at 127k.
Old 03-01-2006, 12:02 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Ckeck warrenty for you cats. They are much longer then the chassis warrenty dur to gov smog regs. Chances are they are still under warrenty...jj
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 03-01-2006, 01:08 PM
MT-2500's Avatar
AF - Advisor
Good idea But.
Not that long. The poster said 143K. Cats are only 80K or 8 years under federal emmisions warranty.
Some more info on cat codes and testing.
DTC P0420, P0421, P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicates bank one catalyst system efficiency is minimum requirement. DTC P0430 and P0430 indicates bank 2 catalyst system efficiency is minimum requirement. Possible causes are as follows: Use of leaded fuel. Oil contamination. Cylinder misfire. Fuel pressure too high. HO2S sensor improperly connected. Damaged exhaust system component. Faulty ECT sensor. Faulty HO2S. Ensure ignition timing is correct. Retrieve all Continuous Memory DTCs. If misfire code(s) is not present, go to next step. If misfire code(s) is present, isolate cylinder and repair as necessary. Check HO2S Monitor DTCs If DTCs P0136, P0138, P0140, P0141, P0156, P0158, P0160, or P0161 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. Check ECT Sensor DTCs If DTCs P0117, P0118, P0125 or P1117 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. If any codes except P0420, P0421, P0430 and/or P0430 were present in step 1), service as necessary before continuing. If no codes except P0420 and/or P0430 were present in step 1), go to next step. Check Rear HO2S Wiring Harness Turn ignition off. Ensure HO2S wiring harness is correctly routed and connectors are tight. Repair or replace as necessary. If wiring harness and connectors are okay, go to next step. Check Fuel Pressure Turn ignition off. Release fuel pressure. Install fuel pressure gauge. Start engine and allow to idle. Note fuel pressure gauge reading. Increase engine speed to 2500 RPM and maintain for one minute. For fuel pressure specifications, see FUEL PRESSURE SPECIFICATIONS article. If fuel pressure is as specified, go to next step. If fuel pressure is not as specified, go to CIRCUIT TEST HC . Check For Exhaust System Leaks If exhaust system leaks, it may cause catalyst monitor efficiency test to fail. Inspect exhaust system for cracks, loose connections or punctures. Repair or replace as necessary. If exhaust system is okay, go to next step. Check For Exhaust System Restrictions Inspect exhaust system for collapsed areas, dents or excessive bending. Repair or replace as necessary. If exhaust system is okay, go to next step. Ć Check Manifold Vacuum Install tachometer. Connect vacuum gauge to intake manifold vacuum source. Start engine and raise engine speed to 2000 RPM. Manifold vacuum should rise to more than 16 in. Hg. If manifold vacuum is okay, go to next step. If manifold vacuum is low, go to step 11). Leave tachometer and vacuum gauge connected. Start engine and raise engine speed to 2000 RPM. On a non- restricted system, manifold vacuum should quickly rise to normal range as increased RPM is maintained. On a restricted system, manifold vacuum will slowly rise to normal range as increased RPM is maintained. If manifold vacuum is okay, no indication of exhaust leak or restriction has been detected and testing is complete. If manifold vacuum is low or slow to respond, go to next step. Leave tachometer and vacuum gauge connected. Remove exhaust pipe from exhaust manifold. Start engineand raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is downstream from exhaust manifold. Reconnect exhaust pipe to exhaust manifold and go to next step. If manifold vacuum is still low or slow to respond, fault is in exhaust manifold or intake manifold gasket. Repair or replace as necessary and repeat QUICK TEST. Leave tachometer and vacuum gauge connected. Disconnect muffler/tailpipe assembly from rear of catalytic converter. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is in muffler/tailpipe assembly. Repair or replace as necessary and test drive vehicle to verify elimination of symptom. If manifold vacuum is still not okay, fault is in catalytic converter. Repair or replace as necessary. Check tailpipe/muffler assembly for debris from catalytic converter. Test drive vehicle to verify elimination of symptom.
Mt
MT
