Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-26-2006, 12:21 PM
FRANKENCAMRY FRANKENCAMRY is offline
5SFE - Ringing noise at idle
My 94 5SFE (in a 93 body) seems to run fine but makes a rigning/whistling noise at idle. Any ideas what this might be? I want it to purr like my buddy's 94.
Old 02-26-2006, 08:39 PM
Shadetree Mechanix Shadetree Mechanix is offline
Re: 5SFE - Ringing noise at idle
Originally Posted by FRANKENCAMRY
My 94 5SFE (in a 93 body) seems to run fine but makes a rigning/whistling noise at idle. Any ideas what this might be? I want it to purr like by buddy's 94.
Could be the "flexpipe". It's the pipe between the exhaust manifold collector and the main exhuast pipe.
Or it could also be the "generic-type" muffler you got compared to your buddy's OEM Toyota muffler.
Old 02-26-2006, 10:05 PM
Just this week replaced the flexpipe which solved a small leak under the heatshield just upstream of the flex. Unfortunately it did not solve the ringing noise. I wonder if a bad or dirty PCV or EGR valve could make noise? Or maybe a bearing somewhere? It seems to be coming from the top of the engine near the valve cover. I've taken the manifold shield off and checked for leaks - none found.
Old 02-27-2006, 09:18 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Use a mechanic's stethoscope or a piece of garden hose and listen to the alternator, power steering pump, the a/c unit and under the timing belt covers. It could be a bearing or a pulley in any of these units. Listen under the timing belt covers to see if the noise is a pulley there or possibly the water pump.
Mike
