Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-26-2006, 11:32 AM
KRZYSZTOF C KRZYSZTOF C is offline
Unhappy Starting Problem
96 contour starts for couple seconds and dies. the things is the car keeps running when i spray starting fluid to air intake. i believe it can be related to a fuel shortage problem. if you have any advice, please respond. thanks in advance
Old 02-26-2006, 02:07 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Starting Problem
never keep a car running on starting fluid..
can you hear the fuel pump kick on when you turn the key? changed the fuel filter?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-26-2006, 07:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Check the fuel pressure bleeder valve and see if your getting fuel pressure.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
