Old 02-26-2006, 12:36 AM
blitz9198 blitz9198 is offline
oil leak
I have a 95 lumina LS with the 3.4L DOHC and it has an oil leak for awhile now...weve replaced a few gaskets here and there yet it still leaks, anyone know of some common leaks on this engine so i can check around some more
Old 02-26-2006, 09:28 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: oil leak
There is an o-ring seal on the oil pump drive shaft that is very common to leak. It is located on the drivers side of the engine, under the throttle body, in the center of the "v". It is essentially a distrubutor with the top cut off. The o-ring is Fel-Pro part #70800, and I also put a #70194 small block Chevy paper gasket in there for added insurance against future leaks. Both gaskets should cost less than $4.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
