Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-25-2006, 10:13 PM
toyotablue toyotablue is offline
Gas pedal dies around 55mph; returns at 50
"90 4x4 pickup V6 3.0
Engine light on, repaired hose to EGR modulator, replaced O2 sensor, changed spark-plugs, wires and distributor. Checked EGR modulator...
Thing dies at random above or around 55mph and then slows to 50 and comes back to life.
Any ideas?
Old 02-28-2006, 02:37 AM
KimMG KimMG is offline
AF - Advisor
Re: Gas pedal dies around 55mph; returns at 50
Fuel pressure?
Old 03-01-2006, 05:01 AM
SidneyCanada SidneyCanada is offline
About half of the ECU codes stored on the first & second generation EFI Toyotas don't show a constant blinking check engine light therefore you must pull the ECU codes to see if a fault is registered.
To pull the ECU codes:
All 1980-1995 and including 1995 EFI equipped vehicle allow you to find engine and related faults by pulling the ECU (computer) codes without the need for a handheld OBDII diagnosis scanner,the sites listed below have the fault codes needed to pull the codes and the instructions on how to do it:
http://autorepair.about.com/library/...bl-dtcs-36.htm
http://autorepair.about.com/library/...bl-dtcs-53.htm
http://autorepair.about.com/library/...bl-dtcs-71.htm
http://autorepair.about.com/library/...bl-dtcs-90.htm
http://www.off-road.com/toyota/tech/codes/index.html
http://lcengineering.com/TechNotes/TechNote12.htm
http://lcengineering.com/TechNotes/TechNote13.htm
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.mad-mechanic.com/toyota/t...tml#obtaincode
http://www.freewebs.com/th3duke/22RE-ECU.mht
http://www.troublecodes.net/Toyota
http://members.igateway.net/~pscott/enginecodes.html
http://www.autobook.co.kr/data_links...uble_codes.htm
http://www.autoshop101.com/forms/h27.pdf
http://www.showmesome.info/hilux/inf...E/Page0096.htm
http://www.efisakh.narod.ru/at_toyota.htm
http://www.usatransdoctor.com/foreigntoyota.htm
Pulling the ECU codes is the first thing I do to diagnosis a problem thereafter I reset the ECU to see if the same problems show up and if so I then take voltage measurements both with the engine running and not and compare with the factory service manual,I also close the ignition switch after a cold engine and also after a warm engine and compare them with the factory service manual.This technique will completely isolate your problem without having to do trial and error and it is the technique I use when repairing tv's,vcr's,home/car audio.
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiB...pair_guide.jsp
1985 Toyota 4-Runner/pickup Factory Service manual:
http://www.jasuza.com/1985toyotatruckfsm.pdf
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mecha...rams/index.htm
http://perso.wanadoo.fr/adherence.4x...techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/a...toyota.manuals
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://aarc.epnet.com/application/8578/8578.htm
http://aarc.epnet.com/application/9316/9316.htm
(1997–2000=4-Runner,pickup,T100,Tacoma,Tundra,Landcruiser)
http://www.bedlib.org/ebsco.html
then click on “AARC” or “Auto repair reference center”
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM
Old 03-01-2006, 05:44 AM
gator2764 gator2764 is offline
When it dies does it go down to an idle? Could be the TPS. Throttle position sensor.
Old 03-02-2006, 04:15 AM
The throttle works fine under 55. Its hard to say if its going back to idle, but the gas pedel dies completely.
Also the valve cover gaskets blew... could it be that a part of the emissions system is blocked or broken? PCV vALVE?
Old 03-07-2006, 03:45 AM
Question Re: Gas pedal dies around 55mph; returns at 50
I could still use some help....
The truck DIES, no idle, but 'push starts' itself when it hits 50mph.
Only happens after 55 mph in any gear (3,4,5)
Runs fine under 55 except rough when coasting downhill while in gear.
Valve cover gaskets blew.
Lost some power and gas mileage has done down.
Engine Temperature has no effect.
Changed O2 sensor.
What can I check next?
Old 03-08-2006, 04:10 AM
AF - Advisor
Have you checked for any stored codes?
Check to make sure all the vacuum lines are correctly connected and are in good order. This includes vent lines to the gas tank.
Check the PCV valve to make sure the crankcase is properly ventilating.
Check the fuel pressure.
Check the valve clearance.
What do your spark plugs look like?
Check the air filter and air intake for obstructions to make sure your motor is breathing.
