Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-25-2006, 09:09 PM
CHAIR O KEY CHAIR O KEY is offline
01 aurora wet floor
Every time it rains? i guess the back floor on drivers side gets wet ,sometimes 1/2 inch or more. Any suggestions on a remedy or cause? Thanx [email protected] Chair o key By the way the only window power lock and mirror that work are on drivers side. Drivers seat heat wont work. Is there any connection? no pun intended!
Old 11-02-2006, 03:32 PM
tmcnall tmcnall is offline
Re: 01 aurora wet floor
I have the exact problem - did you ever figure it out?
sunroof?
drains under the wipers?
Old 11-03-2006, 08:43 AM
baron1701 baron1701 is offline
I had the drain hose for my sunroof on my '95 fall off and cause a signifigant amount of leakage into the car and travel along the floor boards. To check you need to pull the headliner down a little.
