Old 02-25-2006, 08:58 PM
Thorax68 Thorax68 is offline
Question headlight issues. Need some advice.
I have a 1997 plymouth voyager mini-van, about 2 month ago my headlight wont go on, but my high beams work. I have to keep car lights on high beam all the time. can anyone give me a idea what's causing this.
Thanks.
Old 02-26-2006, 01:12 AM
moparman58 moparman58 is offline
Re: headlight issues. Need some advice.
Could be your headlight switch has gone bad. Had to replace mine ('97 T&C) last summer. The old one was worn and you had to play with it to get it in just the right place to get the headlights to come on at all.
Old 02-26-2006, 03:09 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
As moparman58 says, it could be the switch. Before you go there there's a few easy things to check. Go to your Power Distribution Center (a fuse/relay panel) under the hood on the right edge of the engine compartment outboard of the battery. The schematic I'm looking at may not match your van so I won't give you the fuse numbers. Just check all the headlight fuses to make sure none are blown. If the fuses are good, find two relays labeled low beam and high beam relay on the same panel. The labels are on the panel cover. They should be identical relays so just pull them out and re-insert them in the opposite positions. Now, with the relays swapped, if your problem now changes to no highbeams, that relay is bad. Short of removing the relays, you could tap on the low beam relay and see if the low beams come on. Beyond that, except for two bad headlamps (not likely), it gets a little tricky. Try these checks for now and see what you find.
Old 03-11-2006, 08:02 AM
I just checked the fuses and the relays they are good. How do I check to see if it's the switch?
Old 03-11-2006, 02:04 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The switch you're dealing with is called the multi-function switch. Disconnect the negative battery lead to keep the airbags from accidently going off. Remove the lower steering column cover. Disconnect the switch connector. Using a multimeter or test light, check for continuity at pins 9 and 10 at the same time clicking your switch between low and high beams. When you select low beam you should have continuity (0 resistance or the test light lights up). If not replace the switch.
Remove the two screws securing the switch and remove. Install the new switch and secure. This is probably a dealer only part. You could try a junk yard. Keep in touch.
Old 03-11-2006, 11:48 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Make sure that both low beams are not burned out.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-30-2006, 08:15 PM
Proplem solved. There was a short. which burn out the low beams light.
Old 03-31-2006, 01:55 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Great. Thanks for letting us know.
