Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 02-25-2006, 07:57 PM
MooGoCow3 MooGoCow3 is offline
Exclamation DOHC ZC no start. Really need help
I'm a member of Honda Tech but I'm crossing the river because i'm desperate!
I just put my (OBD1) ZC in today and it ran good at first, I drove it around the parking lot, back into the shop and it cut off.
I got codes 14 and 8
cylinder position sensor and IAC valve.
I switched the internals from my D16 distributor to the ZC one to no result. I'm getting fuel and fire but it could be not enough of either. I even switched the fuel rail from my D16 too.
This problem has reduced me to a nOOb and i'm not sure what to do next.
I can help you with a stock honda all day but this has me confuzed.
So please give me some ideas.
And I switched the IAC from my stock engine to the ZC too and even cleaned it and it still acted up.
But i'm the most interested in just getting the darn thing started.
Old 02-25-2006, 09:41 PM
Civic91EF Civic91EF is offline
Re: DOHC ZC no start. Really need help
im new to this forum thing but i have a question about a engine swap. is there any big changes i need to do for a d15b v tec into a 91 civic dx. or has anyone out there alread did this swap, that can explain it to me thanks
Old 02-26-2006, 06:56 AM
Ok i've done a little more research and been able to sleep on the subject.
I had the distributor disconnected to turn the engine over a few times to prime the oil before I started it. They CYP code could have come from that. Also I need to check the ground.
I may have reversed the plugs going to the IAC valve.
Any further insight from that?
