Go Back   Automotive Forums Car Chat > Mazda > MPV
Old 02-25-2006, 06:03 PM
mbryson mbryson is offline
Unhappy not charging mpv
my 1990 mpv won't hold a charge. we have replaced the alternator and battery but problem still there any help would be appreciated
Old 02-25-2006, 10:31 PM
12Ounce 12Ounce is offline
Re: not charging mpv
Do you have a voltmeter? They are very important for finding what is causing this sort of problem.
I prefer the analogue (needle indicator) type for auto work.
During engine idle, the post-to-post battery voltage should be 14+ volts. Anything less leads to problems. Measure another car's battery voltage just for reference. If there is low voltage, it will be caused by low altenator output or bad cable connections.
If the alternator voltage measures OK, but the overnight battery voltage falls to less than 12+ volts .. then the battery is at fault, or there is something draining the battery down.
