Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-25-2006, 05:48 PM
cableguy4k cableguy4k is offline
90 Cutlass Supreme-Stalls
The car will stall intermittenly. It hesitates after coming to a complete stop.
I have replaced the fuel filter,plugs, wires and ignition module. Any thoughts??
Thanks,
Steve
Old 02-25-2006, 06:19 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 90 Cutlass Supreme-Stalls
Dirty fuel filter, bad throttle position sensor, bad crank sensor or torque converter solenoid not releasing. Any of these can cause the car to stall. Only the tps will give you a code when it starts to go bad.
Old 03-08-2006, 11:04 PM
The car now dies every time you come to a complete stop. I have replaced the fuel pump and filter. The 'Service' light does not come on. Where is the torque converter soleniod located at??
Old 03-09-2006, 10:09 AM
Pontiac Guy
On your car there should be a plug on the top of the transmission. Pull the plug and see what happens if it doesn't stall then the torque converter solenoid is not releasing and will need replaced. It is located inside the transmission but you can drive it unhooked without doing any harm to the transmission. You will however see a decrease in gas mileage.
Old 03-09-2006, 04:13 PM
That's what I need to know.
