Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-25-2006, 05:37 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Knocking From Axle
Hey all;
Along time ago I posted a thread about a knocking sound from my front axle. It does it when starting from a full stop, braking, and turning. Someone else had the same problem, and had a suggestion on what it would be. I can't find that thread and I dont remember on who it was by.
I bring this up again becuase about 2 nights ago I was driving and the knocking was going on when I hit bumps, turned every corner, or just moved the wheel. I was getting so pissed I punch it when some people started pissing me off while driving. I dropped it, floored it, and there was a loud BOOM. I though it was a backfire, but my car hasn't done that in a long time, and it sounded like it was came from the front. Afterward tho, it went back to the normal amount of knocking.
I've had this problem since I bought the car. It's gotten worse over the 2 years, but nothing has gone wrong because of it. Engine mounts are new.
What can that knocking be, and how much are we looking at?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-25-2006, 06:42 PM
gstnewb gstnewb is offline
Re: Knocking From Axle
Might be a bearing problem or a CV joint. Go under the car and inspect your CVboots. If one is torn then the chances are even higher that it's all coming from the CV joint or even the bearing. I had the same problem not too long ago on my other car. Now my eclipse has some knocking in the rear only for the first 20 seconds after I start driving the car and then it stops. That is only when the car hasn't been driven in hours and I start driving it for the first 20 seconds and never again for as long of a trip as you wish. I guess it's a lubrication issue with my car or the bearing is going out but yours sounds like one of the two for sure. CV joint or bearing.
1990 Eclipse GS-T (STOCK)
Planned mods: 15 psi boost; turbo timer; blow-off valve; 3" catback exhaust; alum. IC pipes.. for now
Old 02-25-2006, 08:34 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Which side i have a passenger axel
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-27-2006, 05:39 PM
david-b's Avatar
Dave is THAT guy
So I went to my mechanic today to see what the deal is with this knocking. He got in the car and test drove it around. He made 360s and all the goodies, and he heard it. All he did the whole time was complain about how the car rattles so much from the motor mounts. Something in my dash is loud, and my sun roof is also rattles. My alternator belt squeels right now too. He said (in a thick European accent), "You have nothing to worry about. Get the rattling fixed first, then we'll be able to pin point the problem. It's fine and drivable."
Now, he didn't even lift the car up to see if anything was visable. I've trusted my mechanic, but after this one, I dont know now. Also, I took my Olds in there when I had my problem with it, and he hooked it up to the computer and found nothing wrong with anything. I did the ole ODBI jumper test, and got the code and then fixed that. Makes me think if I should trust people. My parents lef ttheir mechanic after they found out I can do everything he did, but cheaper and better. I dont know now.
75 Monte Carlo
Old 02-27-2006, 06:22 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
yep I remember I had the same problem and thought I may have been my cv joint.....but it mysteriously dissapeared. So I never really looked into it since.
....It has been a LONG time...I want to move to FL or Japan.....
Old 02-27-2006, 06:46 PM
ned032002's Avatar
ned032002 ned032002 is offline
Could it be the stabalizer linkage?
Old 03-02-2006, 08:51 PM
showstopperz's Avatar
showstopperz showstopperz is offline
i heard that it could be a upper or lower or both ball joints i know that mittsubishi had a recall on some 2g ball joints but thats just an opinion.
1998 spyder gst 5 speed
2007 Mazda SPEED3
Old 03-02-2006, 09:14 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
I don't know about the ball joint. When my driver side ball joint started to go it was more of a sqeaking not a knocking.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-03-2006, 12:29 AM
david-b's Avatar
Dave is THAT guy
I got the whole control arm and ball joints fixed when i bought the car. I then took it to the dealer and they paid me for the work i had done by a mechanic. Lucky me. So, that's not the problem.
75 Monte Carlo
