firewall access
im going to run a power lead wire (8 or 4 gauge depending on room in the trim and firewall) for an audio system. the question is where can i get it through the firewall without drilling and if i cant where have you drilled that works out well. i heard something about throught the fuse bix but i see no opening there. thanks.
Re: firewall access
Dont go through your firewall, go around it. There are sme holes in your fender wall on the inside of your engine bay. Run them through there and then fish them out through the door using a coat hanger (connect a st8tened coat hanger to the 0 connector of your power, and then drag it through to where your door opens). Then, go through your door, there should be some wires already running through there, so just pull out that boot and run it through with the rest of the stock wires. That way you can easily just run the power st8 to the back under your carpet by the door frame of your drivers side. If you have any questions I can post pics of my setup. Good luck
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: firewall access
i took a look and i see what youre talking about. my only other question is how big of wire can i get through it without any problems? think i can get 4gauge through there or just do 8gauge?
Re: firewall access
I have 4 gauge wire, and it fit fine. Also, for my battery fuse block, i just mounted it on top of my stock fuse block that under the hood. It works great.
