Old 02-25-2006, 12:01 PM
unicyclemidget11 unicyclemidget11 is offline
cut out wiring help please
alright. i got a cut out from street pro. I thought this one of the better cut outs out there. My question is, from the switch there is four wires. One set is short and consists of a black and red wire. The other set coming from the switch is long and also consists of a black and red wire. From the cut out motor, there is a black and white wire. Which wires hook up to where? I'm assuming the longer ones hook up to the black and white one but what color to what color? Also, where can i hook up for the power source. Here's a link to the website's wiring diagram.
http://www.streetpro.us/SSInstall.html
http://www.streetpro.us/SSWireDiagram.html
Old 02-25-2006, 12:15 PM
Re: cut out wiring help please
i have pictures of the cut out but i don't know how to post them. help?
Old 02-26-2006, 12:09 PM
anyone?
Old 02-28-2006, 10:03 PM
catback23 catback23 is offline
Yes the long red and black go to the motor (it doesn't matter which color matches up with which), the short red goes to a fused 12v power and the black goes to ground. Hopes this answers all your questions
Old 02-28-2006, 10:33 PM
where can i hook up to the 12v power and where can i ground it?
Old 03-01-2006, 12:00 PM
You can tap into any fused 12v wire that has at least a 10 amp fuse and the same gauge (size) or larger as the wire coming from the switch. If the line you tap into has a higher than 10 amp fuse I'd suggest you put a 10 amp fuse between the spot where you tap the 12v and the switch. Ground can be gotten from any grounded spot on the car, the chassis is typically grounded or you can even look for the ground points (where ground wires typically meet at).
