Old 02-25-2006, 10:21 AM
macdaddy54 macdaddy54 is offline
Question 2001 blazerspeedometer-abs
2001 blazer when I took off from house ABS light was on and brake light warning on. Speedometer not working and transmission not shifting right is there anything that ties all of this together? I need to find out what to check.
Old 02-25-2006, 11:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 blazerspeedometer-abs
Wheel Speed sensors and VSS sensor.
You need to get a ABS and eng/trans capable scanner on it and get codes and readout sensors.
Post back codes No's.
MT
MT
Old 02-25-2006, 04:07 PM
Question Re: 2001 blazerspeedometer-abs
went through about 40 pgs. of threads and maybe if I cleaned the sensors that may help. Last night I was in cornfield with cornstalks about 1 ft. high. maybe I have dirt or something up in there!!! I was in field because I thought coyotes were back there with livestock!!!!! You think this may be something to chk. on the sensors? And what are VSS? Hard to get somewhere to check codes because of tranny not shifting into higher gear
Old 02-25-2006, 04:51 PM
MT-2500's Avatar
AF - Advisor
Smile Re: 2001 blazerspeedometer-abs
Craw under there and check the wiring to each wheel and look at the plugs in on the trans sensors.
Them cornstalks are hard on wiring. Hit them sidesways instead of head on.
They will even punch holes in rad.
Good luck
MT
Old 02-25-2006, 05:08 PM
GregA's Avatar
GregA GregA is offline
... You think this may be something to chk. on the sensors? And what are VSS? ...
VSS = Vehicle Speed Sensor
And Yes - if that is disconnected, shifting will be HARD. That happened to my van once when I had it repaired and they forgot to reconnect it. Doh!
I would get under the car and check for loose wires/connections.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 02-26-2006, 08:34 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
VSS to me.
Back of the tranny.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-26-2006, 01:14 PM
where exactly on back of tranny? what about ABS light and parking brake light? friend of mine found code says WSS, but have to get reader to tell which one. I thought they were on wheels. thanks
Old 02-26-2006, 01:19 PM
BlazerLT's Avatar
AF -Advisor
on a 4x4 it might be on the transfer case near where the drive shaft connects.
Also clean the front wheel sensors to be sure.
Old 02-26-2006, 01:28 PM
so do I take off calipers and rotor to clean? have to start somewhere b4 going to the shop. are they just on front whls? Thanks, everybody is helpfull!!!!!!!!!!!!
Old 02-26-2006, 01:56 PM
BlazerLT's Avatar
AF -Advisor
Don't think so, you should be able to see them attached the the dust shield.
Old 02-26-2006, 02:48 PM
MT-2500's Avatar
AF - Advisor
First what is the code no?
MT
MT
Old 02-28-2006, 09:02 PM
well got blz fixed tday. speed sensor on top of tranny was unplugged. I could not find it and I spent alot of time searching guess I should have reached around a little bit more up there!!!!!!! Mech. said he dont know how it could come unplugged he said ya have to pull tab then pull apart. Good news is all it cost was $48. now everything finer than frog hair!!!!! Thanks to all for all the help
