Old 02-25-2006, 01:43 AM
animekenji animekenji is offline
R-12 or R-134a???
Does anyone know if a 95 LeSabre has R-12 or R-134a in the air conditioner and if it is still R-12, is there a retrofit kit available?
Old 02-25-2006, 08:49 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: R-12 or R-134a???
It has R134-a. You should see quick connect couplers on the high and low side lines instead of threaded connectors.
Old 02-25-2006, 11:20 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I'm 100% positive its 134a like hotZ28 said.
If you're ever in doubt, there should be a sticker on the front underhood crossmember over the radiator on a piece of plastic. This sticker has warnings, belt routing and somewhere should say which refrigerant to use.
