Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 02-25-2006, 12:08 AM
snowmanjoe snowmanjoe is offline
85 Cimarron-fast idle at startup
My 85 Cimarron has 70,000 miles. When I start it cold it starts idling at about 2000 rpm and then goes down to about 1400 rpm after about 1 minute then takes about 5 minutes to go down to about 1000 rpm. Then when I push on the brake to shift in to gear the rpm increases to about 1500 rpm and then takes a couple minutes to come back down to 1000 rpm. Any ideas? Easy/cheap fixes?
Old 02-25-2006, 07:25 AM
DFBonnett DFBonnett is offline
Re: 85 Cimarron-fast idle at startup
Dirty throttle body can cause this. Clean the throttle bores and plates with O2 sensor safe carb cleaner and a toothbrush. Disconnect then reconnect the negative battery terminal to reset the computer. Worth a shot.
FWIW
YMMV
Old 02-26-2006, 09:14 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Look for a vacuum leak in the intake manifold. Suck a leak allows extra air into the engine, just as if you have your foot on the accelerator.
IMO take a look at the vacuum brake booster first.
Try removing and plugging the vacuum line to the booster (don't drive it!) and see if the problem persists.
Old 04-21-2006, 07:19 AM
sickpuppyz's Avatar
sickpuppyz sickpuppyz is offline
do you know if they have liquid cooling system in cars
