Old 02-24-2006, 11:24 PM
dustinlmiller13 dustinlmiller13 is offline
Compression question.
I have a 1980 model Camaro with 76cc stock heads. If I changed the heads to a 65cc, what do you think my compression would be? What is the highest compression you can run in a stock bottom end?
Anything is possible through Christ our Lord.
1980 Camaro: Base coupe sleeper with 350 4bolt main (stock bore, double humps, 480 lunati cam, flowtech headers). Stock 2.73 open rear (changing next month to 4.10 mini spool).
Old 03-03-2006, 09:04 AM
jveik jveik is offline
Re: Compression question.
it goes up a good amount, prolly 10:1 with good chamber design can be run on 91 or 92 octane... also, i have heard that aluminum heads can go up one point more than iron heads before they have pre-ignition... basically if iron can handle 9:1 then alum could do 10:1... its just a heat-dissapating deal
