Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 02-25-2006, 12:10 AM
haire_11 haire_11 is offline
sunbird MAF sensor location
where is the MAF sensor located exactly on a 93 sunbird 3.1
Old 02-25-2006, 01:32 AM
Re: sunbird MAF sensor location
is it possible that my car doesnt have a MAF sensor because its a 93 3.1 , ive read that it has a MAP sensor because of speed density? i think that has something to do with the air flow being controlled by the intake manifold .... if that makes any kind of sense and if my car does have MAP where is it located
Old 02-25-2006, 09:17 AM
GTP Dad GTP Dad is offline
Pontiac Guy
The book I have does not show a MAF sensor. The MAP sensor is located on the passenger side of the vehicle on the firewall.
Old 02-26-2006, 12:57 PM
i dont think there is any sensor on the passenger side of my firewall .... and its the maniflod absolute pressure sensor so wouldnt it be on the manifold or at least connected to it in some way
Old 02-26-2006, 06:06 PM
Pontiac Guy
Not necessarily! The map sensor is often mounted on the firewall or on a bracket on the back of the engine. They are not usually mounted directly on the manifold especially on the 3.1.
Old 02-27-2006, 02:22 AM
after looking on other sites i figured out that the MAP sensor is mounted to the rear of the motor on the passenger side.... could that be causing my rpms to surge between 750 and 1500 when stopping and coasting around 10km/h...thanks for the help
Old 02-27-2006, 05:15 PM
Pontiac Guy
Yes it can! You can usually replace it within just a few minutes. Used ones are available at some wrecking yards for a reasonable cost.
Old 02-27-2006, 05:52 PM
would any GM one due because they all look the same
