| Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :) |
viper vs veyron
seems to be somewhat dead in here lately, so i have a comparison
speed only!! from a roll, 60mph to 230mph, who takes it and if you can, lets get technical 2005 Hennessey Viper engine Venom 1000 90 Degree V10 position FFront Longitudinal aspiration Twin Garret Turbos valvetrain Pushrod Activated OHV, 2 Valves per Cyl fuel feed Electronic Sequential Injection displacement 8554 cc / 522 cu in compression 9.0:1 power 745.7 kw / 1000 bhp @ Not Available rpm hp per litre 116.9 bhp per litre bhp/weight 291.55 bhp per weight drive wheels RWD body / frame SMC & RIm Panels over Tubular Steel Spaceframe front brakes Brembro Vented Discs f brake size 356 mm / 14.0 in rear brakes Brembro Vented Discs r brake size 356 mm / 14.0 in front tire size P265/35YR-18 rear tire size P335/30YR-20 f suspension SRT10 KW Adjustable Suspension System r suspension SRT10 KW Adjustable Suspension System weight 1556 kg / 3430 lbs transmission 6-Speed Manual 0 - 60 mph 2.25 seconds 0 - 1/4 mile 9.75 seconds related cars Bugatti Veyron engine Quad Turbo W16 valvetrain DOHC 4 Valves / Cyl w/VVT displacement 7993 cc / 487.8 cu in bore 86 mm / 3.39 in stroke 86 mm / 3.39 in compression 9.0:1 power 646.5 kw / 987 bhp @ 6000 rpm hp per litre 125.25 bhp per litre bhp/weight torque 1250 nm / 922.0 ft lbs @ 2200-5500 rpm drive wheels Mid Engine / 4WD front wheels F 52 x 23.5 cm / 20.5 x 9.3 in rear wheels R 54 x 32.5 cm / 21.3 x 12.8 in front tire size PAX 245/690R520 rear tire size PAX335/710R540 weight 1888 kg / 4162 lbs transmission 7-Speed DSG top speed 407.2 kph / 253 mph 0 - 60 mph 2.5 seconds
Re: viper vs veyron
I don't know, can the Viper hit 230?
Re: viper vs veyron
The Veyron seems like it will do better and I think Vipers can only go about 200mph. The Veyron can go somewhere past 250mph, so I take the Veyron.
Re: viper vs veyron
Even if the viper can go that fast I think I would rather go that fast in the veyron. From what I read its very stable at high speeds 200+. Vipers are known for just being powerful with no electronic assists or anything. The viper is likely a better track car but the veyron was made to go to 253 MPH.
Was it just a rumor or are those Hennessey numbers being a little "stretched" in order to make the Viper seem better? I thought I remember a thread on here about that.
Anyway, I'd rather have the Veyron to go top speed in. I personally don't think the Viper could go past 220.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him....... silly rabbit, tricks are for kids... I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL? Quote:
Re: viper vs veyron
i doubt vipers can hit 230, even with the hennessey package. Even 200 would be a strech.
Re: viper vs veyron
Ain't the top speed for a stock Viper 190mph? Thats what I heard.
I've heard stories though, don't know how true they are, about people racing Vipers and once they get around 180 they fall flat. They will still reach 190 but it's a struggle after 175-180.
Re: viper vs veyron
Veryon. It's made to be more aerodynamic at 200+ mph. So when the Viper is getting air drag at 200mph, the Veryon, locked in the "top speed" suspension setting, is literally being 'sucked' to the ground all the way up to 250mph.
Re: viper vs veyron
the veyron was just designed from the start to go that fast, the viper wasent, and i dont think theres much you can do to it to make it cruise smoothly at 200+
1992 Dodge Dakota LE 3.9 In The Works Audio: replace stock speakers with Pioneers, plus two tweeters built into the dash or doors. costume sub box in place of center console, still picking subs, probably a pair of eights Engine & Suspension: Ram air intake, Daul side exhaust, ignition and wires, hoter cam if available, need to learn how to port heads, some kind of cute dress up kit. lowering springs, stiffer shocks, and tie bars, and wheels (Weld Racing perhaps) |
Re: viper vs veyron
aero def plays a big roll
but also, the viper is a whole lot lighter than the veryon with the same amount of power
Re: viper vs veyron
Re: viper vs veyron
exactly!!
732 to be exact
Re: viper vs veyron
what it comes down to is aerodynamics. it took engineers years to make the veyron stable at speeds of over 200mph. i can't imagine imagine how dangerous driving the viper becomes at those speeds since it wasn't engineered with that in mind. so on safety and sanity alone, i'm going to go with the veyron
- 2003 Saab 9-3 Here's a geography lesson: I live in Ely, Nevada. No, that's not by Vegas, it's not hot like Vegas, it's not a desert wasteland like Vegas. I live at 6500 ft. I'm surrounded by mountains. It's really cold in the winter, and never gets above 100 in the summer. |
Re: viper vs veyron
i just checked my stats, and the hennessey viper did the standing mile 25.6 seconds and hit 210mph...and that was with a 15mph headwind and in the convertable! just imagine what the more aerodynamic coupe could do without the headwind
