Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-24-2006, 09:20 PM
cww3rd cww3rd is offline
99 Rear Hatch Lock Actuator Question
My wife drives a 99 Grand Cherokee and the door lock actuator has gone bad. I have a replacement part and know what to do with one exception. The actuator went out with the hatch in the locked position. (Hopefully you can see my problem already.) I went to the local Jeep dealer to inquire about some manual way to unlock the gate and get it open so I can replace the actuator. Much to my surprise, the service guy told me there was no way to manually open the hatch or unlock it from the inside and that sometimes they have to take it to the body shop to get it open. He suggested carefully trying to open the panel from the inside with it shut. Anybody ever had the same problem and have a solution/suggestion?? Thanks
Old 02-24-2006, 10:10 PM
studious03 studious03 is offline
Re: 99 Rear Hatch Lock Actuator Question
im in the same situation please help...
1993 Toyota Camry LE 2.2
1992 Chevrolet Caprice 5.0
1995 Jeep Grand Cherokee Limited 5.2
Old 02-25-2006, 02:00 AM
Bob D. Bob D. is offline
The dealership was being straight up with you; the only way to access it is to remove the interior molding.
Old 02-25-2006, 06:27 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Are you sure the door lock actuator went bad?
The rear door latchs tend to get corroded and cease to work, like you will try to open it but it does nothing, like the door is locked. In this case there are a few things you can do, push in on the door, pull the handle (as to open the hatch) and lift the liftgate. or Give a couple good firm taps with a closed fist right next to the door handle. Make sure the doors are unlocked (using the power doorlock switch on driverside door).
Then once you get it open spray the latching assembly very good with some PB Blaster.
NOTE: I had this problem in my 94 awhile back, I had to always push in on the door and open it that way, Then I got sick of it, and fixed it and this was my fix.
Old 02-25-2006, 10:02 AM
Yes, I'm sure its the actuator. It makes a grinding noise when unlock is pressed. I have the same issue with my explorer and its the same noise. The gears in the actuator have come apart.
Thanks for the suggestion though.
Old 02-25-2006, 08:13 PM
FIXED IT!!!...Re: 99 Rear Hatch Lock Actuator Question
I managed to figure out something that the dealership told me incorrectly (surprise, surprise). I went out this afternoon fiddling around with my jeep and found a small access door near the bottom right of the inside cover. I popped the cover off and felt around in there under the insulation and low and behold I was able to grab the locking mechanism and disengage it, unlocking my rear hatch. After that, there was about 6-8 clips, 4-5 screws and 15 minutes of work and my actuator was replaced. Everything is working like a champ now. Hope this helps someone out there.
Old 02-26-2006, 07:29 PM
BenBB BenBB is offline
The latch is bad on my '96, and i did the same thing that cww3rd did, all you have to do is take out the top screws on teh back molding (and any more if there are any) then if you have enough room stick your hand down there and pull the lever up. If you can't get your hand between the trim and door, stick a small peice of 2x4 in between to space it out, seems to work good.
