Go Back   Automotive Forums Car Chat > Volkswagen > GTI
Old 02-24-2006, 06:43 PM
mck684 mck684 is offline
MK3 GTI 8v cut off
  • Hi, my 2.0 8v has started to 'click' off intermittently, as though the car is trying to turn itself off, but because its in gear it bumps itself started again so just appears to be one big jerk.There is a noticable click from the key area and the rev needle drops for a split second to zero. finally just cut off last night and died. starter works but engine doesnt start, vw dealer has replaced coil and 2 relays, no fault codes appear on diagnostic, ideas??? car is 140.000 miles but fsh
Old 02-25-2006, 03:34 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: MK3 GTI 8v cut off
sounds like a bad ignition switch electrical portion
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 02-25-2006, 05:08 PM
Where is this located on the car? is it something i can fix myself? many thanks for your info.
Old 03-02-2006, 10:08 PM
VDUBMAN
you have to remove the steering wheel, switches and ignition cylinder and then you can remove the electrical portion.
