Old 02-24-2006, 03:20 PM
dj10410 dj10410 is offline
Exclamation another 94 camaro z28 problem
hey guys i recently had my car bogging out really bad and i found out that me cat converter was broke in half and stuck in the feed hole. i had that fixed and that took car of the bogging out. now it seems like when the car is running under normal heat it hesitates and like misses. i did have a burnt spark plug wire and i did not reaplace it i just put some stuff on it to cover the burnt part or the wire. can anyone help me!!!
Old 02-24-2006, 03:27 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: another 94 camaro z28 problem
You need to replace that wire.
Old 02-24-2006, 03:39 PM
will that wire deffinetly cause it to do the things its doin?
Old 02-24-2006, 03:49 PM
wrightz28's Avatar
If it's burned through. Plus you don't wanna mess around iwith it, a coil will throw all the juice it can can iat a resistance wich in this case the resistance would be trying to jump the cracked wire to ground. And it doesn't take much time of this to fry the coil..
You should get a misfire code tho.
Old 02-24-2006, 03:56 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
OBD1=no missfire code.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-24-2006, 04:07 PM
wrightz28's Avatar
I thought the hybrids threw a general misfire code. I know the OBD II are cylinder specefic like P0301 would be "Powertrain, misfire cylinder 1"
Old 02-24-2006, 04:14 PM
FormulaLT1's Avatar
Fight the powwa!!!
nope, no misfire code on hybrids F-bodys.
Old 02-24-2006, 04:16 PM
wrightz28's Avatar
And there's the lesson of the day. Time for a beer
Thanks John
Old 02-24-2006, 04:32 PM
it burned through the outer layer of the wire but there is still the white stuff in the wire
Old 02-24-2006, 04:47 PM
wrightz28's Avatar
Ecxaclty you have no insulation. Why bother trying to cheat around it, jsut get some new wires and route them away for the manifolds.
Old 02-24-2006, 05:00 PM
whit out any instilation will that cause it to missfire or like hisitate during acceleration. And it want burning cause the mantifold it was burning off the headers.
Old 02-24-2006, 05:05 PM
FormulaLT1's Avatar
Fight the powwa!!!
Yes, the outer layer/silicone of the plug helps hold the spark energy in. Just get some wire insulators (like the one's Mr.Gaskets sells) with your new wires and call it a day.
Old 02-24-2006, 05:18 PM
they r tellin me it will take 4.6 hours to put on the plugs and wires
Old 02-24-2006, 05:25 PM
FormulaLT1's Avatar
Fight the powwa!!!
Yeah, they really butt rape you on that at most shops. I have done it a million times on LT1's though, so if you want a hand in doing yours. I'm a hour and half away, We could get it done in about a hour or so (give or take a half an hour.)
Old 02-24-2006, 05:29 PM
you have to change them under neath your car right? im just hoppen i didnt shot the coil because i drove it to school today. how would u know if u blew the coil? by the way ur a lot of help and thanx for the offer on helping
