Old 02-24-2006, 01:07 PM
blakepb88 blakepb88 is offline
96' Ford Taurus Power Steering Trouble
I own a 96' Ford Taurus Station Wagon. About two weeks ago on the highway the speedometer would drop to 0 and then go back up to the correct speed repeatedly. The OverDrive light was blinking as well. I found out that the power steering fluid was empty and put some in. Everything was fine for the first two days. Now, however the speedometer will drop to 0 just once and go back up to the correct speed and the power steering will stop working. What could be wrong?
Old 02-24-2006, 01:49 PM
brokenantimatter brokenantimatter is offline
Re: 96' Ford Taurus Power Steering Trouble
Faulty Transmission Range Sensor
Random Engine Code
Steering Column Problems
Power Control Modulator or another other electrical related malfunction.
Old 02-24-2006, 01:57 PM
Is there any way I can find out which of these it is? The dealership wants a boat load of money to even look at it. Thanks!
Old 02-24-2006, 04:05 PM
A lot of parts stores like O'Reilly Auto Parts, Napa, 4parts and Carquest loan out equipment.
You'll need a multimeter and error code reader to check everything but the steering column and rack & pinion.
The steering column and rack & pinion could be checked by a by a struts and alignment shop for about $60...But you would have to get it there.
I would also get a chilton to learn how to check the various electrical componets.
Old 02-24-2006, 05:10 PM
Thanks. I will try that. Is that loaned equipment quite simple?
Old 02-24-2006, 05:35 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
the speedometer thing makes me think its the Vehicle Speed Sensor
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-24-2006, 05:49 PM
But would that effect the power steering pump?
The TRS tells the computer what gear it is in.
If the TRS goes out it would be just as if the car was in park or neutral.
Old 02-25-2006, 01:49 PM
Thanks! So what I am looking to loan is called a TRS?
Old 02-25-2006, 04:14 PM
..........nononono.......A TRS(Transmission Range Sensor) is a part of the vehicle.
They can loan the tools to check it but they won't loan the part......You have to buy the part if it is broken.
Old 02-25-2006, 04:19 PM
Makes sense, thanks for all your help!
