| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Hi I am new, ummm I dont know if im the only girl here or what but maybe some of you guys might be able to help me.
I have a 95 eagle talon non turbo. I came home from work and turned the car off then about an hour later got in the car to go somewhere else, the car would not start....It would turn over but not fire......Had to have it towed to the garage ....after 1 day they called me back and said the ems or the main computer was out on it. that would cost about 805.00 after parts and labor. Then they called me back and said the cranck shaft sensor was bad ok thats an extra 179 or something like that with a grand total of 990.00 ok the next day they called me back and said they must of got a faulty box and had to get another one cause it wouldnt start again. So they called me back again today and said they got another box but have to have it towed somewhere else to get it programed thats another 100 so now the grand total is 1090. What the Heck.....Do you think I have got ripped off or what? Any advice would be appreciated |
Re: ?
Sounds like maybe you had a dead battery. You might have left your lights on. And yes, yes They are ripping you off royally. Also welcome to the forums. You aren't the only girl but there aren't many. Just remember to post in the proper sub-forums. This would good under the one labeled Problem Diagnosis
1991 GSX 2.3 Stroker |
Re: ?
Here is you
Here is the garage ![]() You are getting massively ripped off.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: ?
listen you eather have a dead battery or your altonator is bad, both of them to fix is pretty cheap...umm there ripping you off hun i would just pick up the car and take it home, if they want you to pay for the work they have done, just tell them you will report them to the better busseness bureu or to your county courts..becuase i work at a shop and i know how guys like to ripp females off from seeing it myself.
Re: ?
She said it cranks over just doesnt fire so I'm confused as to why everyone is saying her battery is dead?
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Re: ?
hahaha yea i get that up here at college, her car turns over but wont fire... DEAD BATTERY!!! im like wtf it turns over its not a damn dead battery.... then dont get me goin on clear flood mode i swear to god mikey here wants to choke a bitch
Re: ?
Yes they are ripping you royaly u can get another ECU from a junk yard for VERY cheep mabey 100 bucks and u can change it yourself only 2 plugs a 3 bolts. and as for the crank sensor same thing very cheep at a junk yard. and only 2 bolts i would tell them to go fuck there self and go buy them at a junk yard and install them yourself.
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
Re: ?
hey girl, throw ur car in yoour sig if you get time!!! and where bouts ya from?
Re: ?
it could be just about anything, fuel pump/filter, spark plug/coil/wires. or something like that. I have had problems like this before, normally if it is turning over it is NOT a dead battery
Re: ?
Hot girl+2g eclipse=extremely sexy
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
Re: ?
My daughters 98 Eclipse did the same thing. It turned out to be the middle fuel pump relay. I don't know if your 95 is the same. On hers there were 3 square black relays on the firewall -drivers side. If the relay in the middle is bad it will cut the ignition. This was a $15 part but it took me a long time to figure out what was wrong. The local Mitusbishi garage said without looking at it that it was probably the ECM. The relay is easy to check. Just look in a Haynes motor manual and it gives you the instructions. A quick way to check it is to switch the relay with the one beside it and see if the car starts. Mine started but wouldn't run right without replacing the bad relay.
Re: ?
definately are shafting you.
I've seen it before. Everytime my sister takes her car in for inspection they pull crap like that. Then I or my dad go in to look at it and "they must have measured wrong" Don't let them screw you over. Even if you have no experience with cars you can change the ecu (it's really simple), and it's cheap to get another one. Take a friend to a junk yard (it will save oyu alot of money) If you don't want to do the work then at least have it towed somewhere else and get a second opinion.
08 Kawasaki Ninja 250R - Plasma Candy Blue 07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD 97 Mitsu Eclipse Spyder GS-T 5 Speed |
Re: ?
I will never take my car to a garage, mostly because of stupid shit like that. $1100 for a bad ECU and CAS? Thats bullshit, you can buy the parts and do it yourself for like $150 and a half hour of time. Are you good with turning a wrench or do you know someone who is? This site, a Haynes manual, and a little elbow grease will save you thousands.... litterally.
Re: ?
This is why I've spent over 2 1/2 years of my life learning how to do everything on my car myself. Girliebomb, I would file a complaint with the BBB if they're listed with them. But seriously, why is there no system in place to make shops not do this? What's stopping them from telling every single person that comes in there's $1200 worth of repair work when really the battery cable just came off? There should be random state inspections where they send in a car and see if they are honest. If they're not more than three times-shop licence gone forever and all employees caught trying to defraud customers taken to jail and never allowed to be a mechanic again-problem solved.
![]() '99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed) Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/ Adopt pets in need! http://www.petfinder.com/
Re: ?
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
