question about my remote
How would i know if my car came equipped with an alarm, my car has the little spot on the front of the dash where the light would be for an alarm and the little bump that would look like the light itself, but i cant tell if theres a bulb in there or if its just a plastic cover where there would be an alarm. my keyless entry remote that was with the car when i bought it only had the three buttions, lock unlock and trunk release, it diddnt have a panic buttion, but the remote never worked, so it got me thinking, since its a used car, could the previous owner just have bought the wrong remote? if anyone needs to know my vin # or the model of the remote if thats helpful. thanks in advance! p.s. i've tried reprogramming the remote SEVERAL times already, even the dealer tried, it would enter the programming mode, but diddnt work still. i put a fresh battery in the remote too. the car's a 98 GTP if you diddnt see in the pic
2006 Chevy Cobalt LS |
Re: question about my remote
Hey Mike, get me the last 8 digits of your Vin, and I can tell you.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
k last 8 digits are wf217587
Mike, your car has remote entry, but not anti-theft, that's why you have a 3 button transmitter, not a 4-button. The correct number transmitter for your vehicle is 10246216.
10246215 and 10246216 are interchangeable.
The remotes have identical circuit boards inside, and the "3 button" remote has a 4th button circuit, which just doesn't have a panic button on the case to be used.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
ohh ok, thanks for checking up on that for me, i was thinking of just getting a new remote to see if that works, if not i know where the recever is, i remember hearing that its behind the instrument cluster pannel, but if it enters programming mode then wouldnt that mean the receiver is good then still or not?
If you enter programming mode, the receiver is functional.
So is this 4th "anti-theft" button just adding an annoying siren to our car? What other extra protection you get out of it? |
A lot of Grand Prixs have the BCM-4 (Level 4) which has a shock sensor. An impact or movement after arming will cause the horn to sound off and the lights to flash.
-2002 Grand Prix GT Black
The way to tell is to open the small access cover at the left hand side of the dashboard after you open the door. Look for something that looks like a relay or module. It will have a sensitivity knob for adjustment located on it. The body control module and daytime running lights module (DRL) is right next to it in the same area.
SNKPWR, give me the last 8 digits of your vin and I can tell you. Bob is correct in that if the car came factory with the anti-theft, it will have a different controller with a sensitivity adjustment, and a 4 button remote. Without anti-theft they come with a 3 button remote.
Thanks!
When done, just turn the ignition back off and replce the fuse. The manual had instruction for all sorts of settings, like length of dome light bening on after closing doors, etc. Most useful information in one of those I've ever found.
2000 Pontiac GP GT 2000 Mazda 626 LX |
Your car comes with the 4 button remote, although it doesn't specify in the GM computer if it has the anti-theft package. It may have become standard equipment in the 02 model year, and that's why it doesn't list the option code for anti-theft(UA0) or keyless entry(AU0).
