Old 02-24-2006, 08:29 AM
salu salu is offline
Angry How to remove window panel from 1997 chevy blazer
My washer fluid is leaking in the rear thru the lift gate, not being sprayed on the rear window.
How do I remove the plastic panel on the inside of the lift gate so that I can
re-attach the hose the loose hose.
Thanks
Old 02-24-2006, 09:36 AM
manwiththeplan88's Avatar
manwiththeplan88 manwiththeplan88 is offline
Re: How to remove window panel from 1997 chevy blazer
Its very simple to take it off, just remove these screw on the pictures. They are on the corners of the tailgate on each side.
1997 Blazer LS 4dr
180,000 miles
Old 02-24-2006, 02:03 PM
billibong's Avatar
billibong billibong is offline
You might want to look at this thread http://www.automotiveforums.com/vbul...79#post3687279
It covers some of what you are talking about. Hope that it helps.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
