Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 02-23-2006, 11:00 PM
CODITHsaves CODITHsaves is offline
210hp intake
the newer eclipses, the GTS with the variable intake on it that makes 210hp, does that have a noticably wider power band also or not such a big deal
Old 02-24-2006, 02:04 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: 210hp intake
IDK, but I still think that the 2000 Fed. Spec GT is the best 3G.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 02-24-2006, 01:46 PM
Re: 210hp intake
Fed. Spec - whats that now?
Old 02-25-2006, 12:01 AM
Boogy886's Avatar
Boogy886 Boogy886 is offline
Re: 210hp intake
federal specifications...conforms to federal specifications on smog as opposed to california specs which are more constricting and produce less power...
Old 02-25-2006, 02:02 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: 210hp intake
see "comprehensive guide to modifying your 3g"
not a real big difference b/t GT and GTS
differences are listed in the above thread too (some of them)
basically, higher compression, and a more even intake manifold... nothing an intake can't remedy, and usually the GT's are better off in the end anyways
uhem, read the stickied posts at the top of the page...
Don't act like you don't love it.
503/2000
Old 02-26-2006, 01:42 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: 210hp intake
the intake doesn't make 210hp.
the extra 10hp comes from the intake manifold and the 10:1 CR pistons.
Old 02-26-2006, 09:26 PM
Re: 210hp intake
the part i was trying to focus on was the power band. The whole point of a variable intake is to widen the power curve and i wanted to know if any who have driven both the normal intake and variable intake notice the difference in that respect
Old 02-27-2006, 10:17 AM
Re: 210hp intake
for a near stock car, you will not feel much of a difference. now, if you were boosted, then that would be a difference story.
