Old 02-23-2006, 11:35 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Unhappy help! crate motor overheating!
So it started up fine, but it's heating up real quick, rising up past 220 in a matter of 5-10 minutes. I've been shutting it off because I won't let it run that hot. It's also drinking coolant like nothing I've ever seen before. I can't tell if it's burning off or what, but I definitely know it's not leaking out anywhere. The 160stat is brand new, water pump is working because I can feel the coolant in the hoses. Any ideas on what the hell is going on?
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 02-23-2006, 11:39 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: help! crate motor overheating!
Air?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 02-23-2006, 11:46 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
1. what color is the exhaust 2. how much coolant have you put in it 3. did you bleed the system of air?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-24-2006, 12:47 AM
tcfco2005 tcfco2005 is offline
and did you change the cooling fans out or anything
1991 RS
305 T.B.I.
700-R4
Old 02-24-2006, 05:55 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
You most definetly have air in the system and do yourself a favor if you did not already and get a custom prom. That way your fans come on much sooner.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-24-2006, 08:04 AM
SG007's Avatar
The fan's not coming on at all. And how do you bleed air from the system??
Old 02-24-2006, 10:25 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Easiest way is to jack the front end up and make the radiator neck the hightest open part of the system. Take the cap off and crank it up. Let it run til the stat opens then top it off, keep runnig it until there are no more bubbles in the coolant.
If the bubbles don't go away, i hope you didn't throw your receipt away for the motor.....
Don't you live in a cooler climate? Think the 160* may be a little bit much.
Old 02-24-2006, 10:28 AM
wrightz28's Avatar
Oh, and the fan, take the connector off of the sending unit (between cyls 6 & 8) and ground it to see if the fan comes on. Could just be a loose sending unit? Also never use teflon on these, they are a tappered thread.
Old 02-25-2006, 12:23 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
whats your timing like?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 02-25-2006, 09:03 AM
SG007's Avatar
It was the fan, it's only coming on with the ac/heat so it's gotta be re-wired. Other than that the car is NASTY. lol
Old 02-25-2006, 10:38 AM
thats great
Old 02-25-2006, 11:51 AM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
thats awesome, good job on finding it out before blowing it up lol
Old 02-25-2006, 03:06 PM
SG007's Avatar
thanks, buddy!
Old 02-25-2006, 06:22 PM
sweet...that thing loogs good in there....as foose would say its like a diamond ring when you open the case...
1991 RS
305 T.B.I.
700-R4
