Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 02-23-2006, 09:26 PM
devinfish420 devinfish420 is offline
1984 dodge ram,has new battery and new altenator but battery drains???
i have a 1984 dodge conversion van 250,it has a brand spanking new battery and alternator,and new belts ,butt the battery has died, and needs a recharge,what else can drain my battery..please help,and thnx,,,D
Old 02-24-2006, 08:38 AM
98Pontranport's Avatar
98Pontranport 98Pontranport is offline
Send a message via AIM to 98Pontranport
Re: 1984 dodge ram,has new battery and new altenator but battery drains???
Hi
I just bought a '86 dodge Ram B150 van with a 318 and have encountered the same problem. I just bought a new battery at Walmart last night(model Dt-3N for the top and bottom terminals or model # 34-3N for the top mounts only), well anyways, it's still not enough cranking power. I'm going to bring it back and buy the $59.99 heavy duty one. The one I bought was $42.99.
Depending where you live, you may even need more cranking power. I'm up in NY, up by Canada, very cold weather=more cranking amps.
Old 02-24-2006, 09:54 AM
I just got off the phone with one of my Dodge buddies, he said for the 318 we should ahev no less than 700 or 750 cold cranking amps and receommended a Decker battery. He said Decker comes with a lengthy warranty(like 5 years) and is American made.
1986 Dodge Ram Van B150, 318 V8
Sweet!
Old 02-25-2006, 04:44 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Did you replace the voltage regulator?
With the engine running check the voltage on the battery from post to post with no accessories turned on. you should have a reading close to 14 volts.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 02-26-2006, 01:54 PM
thnx, i will try the voltage regulator next, if i can find it,......time to buy a chiltons manual i guess..:}.......buy the way ,i was wrong, the van is a 1987 ,250 ram, not a 1984, wooops,,...thnx again...... D
