Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 02-23-2006, 10:11 PM   #1
markyduche641
markyduche641's Avatar
Send a message via AIM to markyduche641 Send a message via MSN to markyduche641
96 crown vic loud noise in front end?
wondering if anyone might be able to give me a litlle advice, my 96 vic makes a loud rattling noise when going over rough roads, to best describe it, it almost seems like the front brake calibers are bouncing against the housing they are bolted to on to, but i know its not the problem, but it has that lound metal banging on metal sound. its not the struts as far as i can tell, everything else seems pretty tight, and suggestions would be appretiated, thanks
markyduche641 is offline   Reply With Quote
Old 02-24-2006, 07:39 AM   #2
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: 96 crown vic loud noise in front end?
There is a small link that bolts to the sway bar. Check these.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
Old 02-24-2006, 08:09 AM   #3
markyduche641
ok, ill check it out, i figure its gotta be something that has to do with a bushing or the like, makes a hell of a noise over bigger bumps, thanks for the advice.
Old 02-24-2006, 07:00 PM   #4
fleettech
check the sway bar links,upper shock bushings will wear out and beat up the hole.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
fleettech is offline   Reply With Quote
Old 02-25-2006, 09:15 AM   #5
markyduche641
thanks fleetech, im thinking its gotta be somthing like that myself, gonna check it out asap.
