Go Back   Automotive Forums Car Chat > Chevrolet > Tracker
Old 02-23-2006, 08:44 PM
cmecedar cmecedar is offline
shifting problems
I have a 99 tracker 4 wheel drive. a week ago I stopped at a traffic light in 2nd gear and when the light changed, I could not get it out of 2nd gear. After a lot of jiggling the shifter it finally went into 1st and shifts through the gears, but it is hard to get into 1st and it grinds a bit if I try reverse, so I shut the motor off before shifting into reverse and then it will shift into 1st but is hard to get in. There were no problems whatsoever before last week and it started all at once. I was reading about a problem with the cluch cable on a 95 tracker. Could this be my problem? Any suggestions? I would appreciate any input before I take it to a transmission shop.
Old 03-27-2006, 09:38 AM
arm2006 arm2006 is offline
Re: shifting problems
You might be onto something with the clutch cable: Might need to be recalibrated. Have you looked at it? Have you checked the transmission fluid level? Are you an experienced Standard driver? The clutch might be gone.
Old 04-23-2006, 08:09 AM
nemesisn4ser nemesisn4ser is offline
From the moment I bought my tracker 7 years ago I have had problems shifting from 4th to 3rd and from 2nd to 1st. I feel your pain. 140K miles later and my clutch is still going. I decided to leave well enough alone though yours sounds more serious than mine. I am not sure if this was just a manufacturers defect or not but the dealership told me many years ago there was nothing they could do with it.
Old 05-25-2006, 05:15 PM
entrail entrail is offline
I am looking at buying a 01 tracker and it seems really hard to shift, from 2nd to first of from N to 1st seems the worst. The thing runs smooth and there is no grinding or anything. I was wondering how common it is with them in regards to hard shifting.
Old 08-11-2006, 03:51 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Doesn't the '99 have a hydraulic clutch? I know the '00 does..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
