Old 02-23-2006, 08:42 PM
dougger dougger is offline
Question Amp Installation Question
I am going to install a small amp to run a small 8" sub that is under my backseat. My question: When you hook up the power do you have to run a ground wire all the way to the Factory Head unit? I know that Delco used to use a floating ground and if you hook to a ground other than the head unit, it blows the Factory Radio.
Thanks for the help.
Dougger
Old 02-23-2006, 10:18 PM
onehate02 onehate02 is offline
Send a message via AIM to onehate02
Re: Amp Installation Question
No. ground it as close to your amp as possible, ground it to any pure metal. Don't let the ground cable be longer than 24 inches, else it wont be a strong ground. The power cable runs to the battery, and the remote turn on cable is what runs from the amp to your headunit... along with the rca's.
2004 Silverado ext. cab 4.3L
Pirelli Scorpian A/T 275's
Magnaflow straight-through muffler (dumped)
K&N FIPK
Custom sound system (alpine/infinity/monster)
Billet Grille inserts & bowtie
Xenon blue bulbs (high/low/drl)
Limo Tint all around
Gaylords X-2000 tonneau
Rhino bed liner
Code Alarm keyless entry system
Custom PA system (dual speakers)
A1 Power Window mod
Center console swap
Old 02-24-2006, 09:29 AM
Faze3's Avatar
Faze3 Faze3 is offline
I grounded mine to one of the bolts under the back seat, nearest the door.
Its not the one that holds the jack, but the one that's not painted. I think the nut was 1/2" or so in size.
Old 02-24-2006, 11:55 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
you want to make the ground as short as you can and straight to the body and make sure the wire is the atleast the same size as the power wire is. then the remote wire goes to a acc. power off the radio or remote output if it is aftermarket. rca's to deck and power straight to the battery. you can run a ground from the amp ground to the radio ground if you want, they used to recommend doing this back in the day but it is unheard of with all the new amps and radios these days.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 02-24-2006, 01:12 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I grounded mine behind my amp rack to the floor of the truck w/ self tapping screw.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 02-25-2006, 09:45 PM
Thanks all. Did the install today and grounded to a bolt right by the Jack and it worked Great! Thanks again.
Dougger
